BottleRocket & Fox Van36; Stack or Zero-Stack Headset?- Mtbr.com
Results 1 to 6 of 6
    211 is offline
    Aug 2010
    Hi, I'm wondering if I should go stack or zero-stack headset on a bottlerocket with a Fox Van 36rc.
    This will be a universal bike, pedaling, single track, and steeps.
    Any suggestions?
    Dec 2009
    If you could put a zero stack in I would to lower the front end a little. Don't know if you can though???
    211 is offline
    Aug 2010
    Quote Originally Posted by Damienp
    Lowering the front end is an obvious affect caused by the zero stack. This much I am aware of.
    I guess my question is for others riding the same config (Fox 36 w/ stack or zero-stack), What characteristics of the bike change and which config do you prefer?
    Most use standard cup with the 36. Slackens the bike a bit and raises the front a tad also. If you were running a Totem or Fox 180 I would use a flush cup.
    Zero Stack headsets will not work , OD is 54mm. Flush cup is what you want 49.5 mm OD.
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
    211 is offline
    Aug 2010
    Quote Originally Posted by Chad_Money
    Thanks for the reply.
    I thought zero stack and flush cup were the same?
    I've been calling anything where the bearing sits below or "flush" with the surface of the head tube zero stack. Oh well...
    At any rate, based on your suggestion I'd still need a standard stack with a reducer for 1-1/8 steer tube.
    Thanks again
    i like rocks
    Reputation: euroford's Avatar
    i have ran both a flush (cane creek double xc er something) headset and a standard cup (king) and i prefer the geo with the standard cup.
    Tim M Hovey
    Nukeproof Mega 290
    BlkMrkt Mob
    1950 CJ3a
    1999 F350 PSD
    2006 E55 AMG Wagon
