Worlds Smallest Chainsaw - Good Trail Maintenance tool?- Mtbr.com
Results 1 to 29 of 29
    ¯\_(ツ)_/¯ SuperModerator
    Reputation: Klurejr's Avatar
    Anyone ever used one of these? Seems like a great little tool that can fit in a backpack for trail maintenance.
    https://youtu.be/YG32KvBtt90
    Ride Bikes, Drink Craft Beer, Repeat.
    Know these before you post:
    MTBR Posting Guidelines
    Reputation: Nubster's Avatar
    I have a folding saw that makes quick work of anything up to around 3-4". There's also the pocket chainsaws...chainsaw blade with handles on each end that does pretty well with larger stuff.
    Worlds Smallest Chainsaw - Good Trail Maintenance tool?-41c214dc-e960-450e-a4cf-e20b4d2f11a3.jpg
    https://www.amazon.com/Chainsaw-Para...chainsaw&psc=1
    Super snowflake = when an avatar offends you so much you have to cry about it and report it to admin. Life must suck for you.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Klurejr View Post
    seriously looks like the only thing it's good for is cutting your fingers off.
    Reputation: life behind bars's Avatar
    May 2014
    Yeah, uhh, no.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    Reputation: tbmaddux's Avatar
    May 2012
    It took him about 20sec to cut through a 1x4. Pretty sure I can do that with my Silky, and I don't have to figure out how to power it.
    since 4/10/2009
    Quote Originally Posted by tbmaddux View Post
    what's the point? I have a folding silky I use at work and agree - this thing looks significantly slower, and no less effort, either.
    How is this better than a battery powered reciprocating saw? I think there's good reason it's not available in the US
    Nowadays with bigger 18v lithium batteries a Milwaukee or Dewalt recip sawzall can do the work.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    this. looks like my silky can equal that thing in speed, and the silky
    can take on much larger stuff
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Apr 2005
    It's cute. I'll give it that.
    WillWorkForTrail
    Jun 2012
    Honestly? I've got a big set of Corona loppers that will probably cut anything that will and do it in a fraction of the time. If I need something portable to cut something larger, I've got a folding corona saw I keep in my pack. That thing? That's a novelty item or something. I honestly can't figure out what possible purpose that could serve.
    Reputation: sturge's Avatar
    looks useless to me...my $20 folding saw from Lowes is lighter, easier to carry and cuts way bigger things much faster. Just used it yesterday on two 5" blowdowns...took all of 2-3 minutes and I was back on the bike.
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...:thumbsup:
    EAT MORE GRIME
    Nov 2013
    Quote Originally Posted by Cotharyus View Post
    it would be good for landscapers trimming and pruning bushes, that's about it
    since 4/10/2009
    Quote Originally Posted by 127.0.0.1 View Post
    there are better tools for that job, too
    Nov 2017
    Seriously.
    Moderator Moderator
    Reputation: Harryman's Avatar
    I timed a casual cut on a 14" spruce with a silky katana boy at 4 minutes. You need to cut a lot of trees per session to not be able to handle it with a silky.
    Feb 2013
    I bought a small black and decker 20v cordless electric chainsaw from a pawn shop for cheap, I think it came with a hedge trimmer (which I love for trail maint).
    The problem with the cordless electric chainsaws is that they don't have anywhere near enough power to remove that wide gap of wood that the chain teeth cut out. A narrow blade is a lot more efficient, I use a small bow-saw that fits in a pack, it works a whole lot better than the 20v chainsaw. I've given up on the chainsaw. When I got it, the chain was on backwards, the previous user must have really been disappointed with it's performance!
    skidding is the signature of the novice; learn how to use your brakes.
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by jimPacNW View Post
    I used a cordless Stihl chainsaw a few weeks ago and ripped through a 12" telephone pole in less than a minute. I decided then that my next saw would probably be electric.
    I brake for stinkbugs
    WillWorkForTrail
    Jun 2012
    The real problem with that saw is it's 20v. The smallest saw you'll find of any real quality is 40v, and many are 60v. I'm sure I don't need to explain the math there. These electric saws are great for cleanup jobs on the trail.
    Reputation: JustMtnB44's Avatar
    I think Bosch intended for the mini chainsaw to replace tools like jigsaws. Definitely not useful for any kind of trail work, as a folding saw would be way faster and could handle bigger stuff.
    Full size battery electric chainsaws are perfect for trail work and clearing larger fallen trees - quiet, no mess, easy to use.
    EAT MORE GRIME
    Nov 2013
    I see this as landscaper tool for those who's wrists get beat with felcos or otherwise fatigued from non-powered pruners. ideal for that, plus can reach in and it grabs the branch. for trail, a silky bigboy is far lighter, better cutter, and can take on bigger stuff.
    May 2013
    since 4/10/2009
    Quote Originally Posted by JustMtnB44 View Post
    I dunno about that. Big advantage of a jigsaw is that you can easily do curves with it. And with the fine teeth, smooth cuts. This thing? Straight-ish lines at best. And rough cuts.
    Maybe. I just see battery life to be a major limitation for something like this. I use felcos at work, and honestly use them on stuff far smaller than I'd bother with using a powered saw. I use bigger pruners for stuff like that. And a big advantage of larger pruners is their extra reach. Which this tool just doesn't offer.
    Dirt Monkey
    Another solution for a problem that didn't exist.
    May 2012
    Ok, so next time you want to hate ebikes or wilderness bills or IMBA or Lycra or goggles or people who skid in corners or the fall line or water bars or leaves or flowers or Strava or shuttles or DH or XC or enduro or freeride or people with too many toes or those things they inserted into paper magazines that fell out in your lap – hey, remember magazines? they’d mail them to you so you could read them – or full suspension or dropper posts or carbon or 29ers or ANY of that, instead, just hate this tiny chainsaw!
    May be good for cutting brush for someone with bad elbows or wrists but otherwise useless. You can use it with one hand while the other holds the branch, recip takes 2 hand unless you're really strong. Otherwise waste of money.
    There's a big difference between ripping and skidding. Those who skid don't know how to ride.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    The 18v Hackzall is the one handed recip saw, and works well with a pruning blade. But a Silky or other hand saw is still way faster. It seems a lot of r&d money is going into making battery powered forms of everything, because they are perceived as being superior by novices. That said, I have a 40v 16" cordless chainsaw, which replaced my stihl ms250 some years ago, and I never looked back.
    I ride with the best dogs.
    I usually carry three of these in my pack, as they get dull quickly, then I take them home and sharpen them under a microscope. Works great, and the three saws only weigh nine times more than the big silky. They buzz through a 3" oak in less than 20 minutes!
    Nov 2017
    Silky folding saw, cut was bigger than the blade.
    30 minutes total stop, probably 10-12 minutes cutting per side.
    Aug 2016
    My 18" Corona pruning saw or big-assed bypass loppers sure as hell going to get the job done faster than that gag gift chainsaw.
    I have three chainsaws from 14" to 20" bars and sometimes wish for something just a little smaller for the longer hikes in to remove fallen cedars. I know two guys using 12" bar chainsaws - one battery-powered,and the other gas and realistically that's as small as what works well here in Pennsylvania.
    Maybe for carving the Thanksgiving turkey? 😉
  1. Worlds Smallest Singlespeed
    By Your Bike Sucks in forum Singlespeed
    Last Post: 12-12-2016, 02:49 PM
  2. Replies: 12
    Last Post: 11-24-2016, 01:34 PM
  3. OT - Cordless Chainsaw 1/2 off - ATTN Trail Builders
    By ask in forum Where are the Best Deals?
    Last Post: 11-30-2015, 03:23 PM
  4. Replies: 8
    Last Post: 04-21-2014, 06:18 PM
  5. Giant Tool Shed Multi-Tool - Ten Bucks - incl. chain tool
    By aa240sx in forum Where are the Best Deals?
    Last Post: 06-23-2011, 11:17 AM
