unicycle platform- Mtbr.com
Results 1 to 11 of 11
    humber river advocate
    unicycle platform
    a thursday night project... so many people ask for this... though
    broadcasting from
    "the vinyl basement"
    build trail!
    gran jefe
    what, no suspension?
    featherweight clydesdale
    Reputation: Fattirewilly's Avatar
    Dec 2001
    So is this used to transport bridges and lumber? Does it work well? Does it require one person or two to balance it? Lots of people probably have an old fork and 26" wheel sitting around, interesting idea.
    Charlottesville Area Mountain Bike Club
    www.cambc.org
    Ride da mOOn Moderator
    Reputation: NEPMTBA's Avatar
    Good job!
    Anything that makes life easier the simple way...
    ... is worth "positive rep" and a +1
    gran jefe
    Quote Originally Posted by Fattirewilly View Post
    Not to be too thick, I don't understand what it does or how it does it either.
    Hermit
    Reputation: swampboy62's Avatar
    Quote Originally Posted by Bill in Houston View Post
    It's a single wheel with a "clamp" on the top. Loosen it up and put in the lumber or bridge deck that you want to move into position on the trail. It takes one person each end to keep it balanced and move it forward, but the wheel bears most of the weight.
    Pretty clever. I'd seen backwoods hikers carts like that thirty years ago, but that is a great idea.
    Steve Z
    Pedaling when it's dry
    And paddling when it's wet
    My insignificant blog:
    http://swampboy62.blogspot.com/
    gran jefe
    Quote Originally Posted by swampboy62 View Post
    Steve Z
    ahhhh, nowwwww i get it. thanks! positive reps all around!!
    I need skills
    Thanks for being brave,
    I didn't "get it" either.
    Cutlery Fiend
    Mar 2011
    How did you attach the bottom plate?
    If you used a flat top plate (yeah I know you probably just used what you had on hand) you could probably use some big honkin' wingnuts to speed things up instead of fooling around with wrenches to tighten down the top plate.
    Quote Originally Posted by KnifeKnut View Post
    use adjustables, works well. i'm always surprised how much weight i can move with this rig...
    broadcasting from
    build trail!
    Cutlery Fiend
    Mar 2011
    Adjustable C-clamps instead of the threaded rod and nuts in your photo, and instead of the wing nuts I suggested, you mean?
    I am still unclear as to how you attached the bottom angle plate to the steer tube. I still have to learn how to braze and weld.
  1. Anyone own a unicycle?
    By mmik in forum Beginner's Corner
    Last Post: 06-21-2011, 11:54 AM
  2. Shock for FSR suspension: Platform or no Platform?
    By Nick_M2R in forum Downhill - Freeride
    Last Post: 10-02-2010, 05:47 AM
  3. Do platform-style frames need less of a platform shock?
    By snovvman in forum Shocks and Suspension
    Last Post: 06-04-2010, 11:08 PM
  4. DH platform or non platform rear shocks ?
    By keen in forum Downhill - Freeride
    Last Post: 02-03-2006, 10:40 PM
