Thinking of building a tiny trail behind my house- Mtbr.com
Results 1 to 12 of 12
    Aug 2014
    I recently moved to a house, and I've got a very small amount of woods behind it on my property. The area I have to work with is about 150 feet wide and 50 feet deep or "in" away from the road. The biggest problem is it's very steep. The hill is around 35 degrees steep, steep enough to be difficult to walk on, some serious benching will be required. Attached is a picture of the area. The trees are rather open in the area I was standing for the photo but are quite thick on the other end of the property.
    What I'm thinking is ride down, have a small table top (1 foot high or so), then ride back up, probably with a switchback on both ends. Biggest concerns are making the switchbacks wide enough and shallow enough to ride. Is this worth pursuing? Am I going to be able to pack down the dirt to make it firm? I've noticed newly built trails are always soft, and I don't know if it's time/weather or use that eventually packs it down.
    Shartacular Spectacular
    Reputation: Shartist's Avatar
    Aug 2018
    Steep sounds fun, be wary of drainage and places water could collect. Enjoy that loose brown pow while it lasts! Itíll pack down as you ride.
    18í SC Bronson C
    Grip2, Reserve 27's, i9, Float X2
    18' SC V10
    Fox 40 w/Avy air/coil, WAO: The Outlier, i9, Avy Woodie
    Aug 2014
    Another question, I've more or less chosen where to build the trail, going down and across the hill, and I've measured it to be about 15 degrees using an iPhone app. That sounds steep, but the section is only about 20 feet long. Is it climbable?
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    it's definitely climbable
    question is are you personally up to it ?
    it's a simple power grunt... should be cake
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Aug 2014
    That's pretty much the answer I was hoping for. I'm fine with breathing heavily at the top of it. My bigger concern was whether or not the average rider would loose traction or have to give up.
    Moderator Moderator
    Reputation: Harryman's Avatar
    It's on the steeper side, but perfectly climbable. A lot of the accepted build rules commonly used on public trails can be thrown out the window on a private trail with only a handful of users. Make it as narrow as you can deal with to cut down on how much material you have to move, the switchbacks would be the biggest black holes. Maybe buy a bunch of beer and have a build party with your buddies?
    You gotta ask yourself though, in reality, how many times are you actually going to want to just ride up and down the same 20' hill? Unless you've got some pretty serious OCD, I'd imagine it would get old incredibly quickly.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    Aug 2018
    Quote Originally Posted by Harryman View Post
    Orrrr... head to home depot, buy a bunch of 'buddies' [for the day] and have a build party with your beer?
    18í SC Bronson C
    18' SC V10
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    Great video series on whats possible with a small space.
    https://www.youtube.com/channel/UC1i...0D8lZvhtqetHmg
    Making shit harder than it needs to be isn't awesome, it's just...harder.
    Aug 2014
    That actually looks like a fair amount of space. Great channel, thanks for posting!
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Quote Originally Posted by slapheadmofo View Post
    See if you can poach some of your neighbors land, no one else will want to ride your trail unless you add some distance. Any other trails you can connect to? Careful on that steep terrain you don't want to turn it into an erosion scar in a few years, steep takes a lot of maintenance.
    I ride with the best dogs.
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Quote Originally Posted by bsieb View Post
    (...)Careful on that steep terrain you don't want to turn it into an erosion scar in a few years, steep takes a lot of maintenance.
    This. Be very careful with erosion, not only on the steeper area. When I'm working on some feature my main concerns are safety and how I can make the water drainage prevent erosion and if possible improve the current status.
  1. tiny tiny pinholes in tread UST
    By diskus in forum Wheels and Tires
    Last Post: 06-27-2011, 02:35 PM
  2. RR: the desert behind my house (north of Thorp)
    By verslowrdr in forum Washington
    Last Post: 03-01-2011, 02:08 PM
  3. The trail behind my house - the saga continues
    By Jisch in forum Riding Passion
    Last Post: 04-19-2007, 07:12 PM
  4. Trail Behind My House - RIP
    Last Post: 11-03-2005, 07:50 PM
Members who have read this thread: 4
