Rounding edges of rock?- Mtbr.com
Results 1 to 6 of 6
    Have a bunch of 8-9" thick limestone chunks that I got from someone that was taking out a retaining wall last summer and am looking at creating a rock garden.
    A lot of the pieces were split from larger pieces either by hand or via cutting tools, so the edges are sharp enough that it makes me a little nervous about cutting up tires & potential injury.
    Wondering if anyone knows a good approach to rounding off or at least sort of smoothing the edges of rock. Not looking to turn this into something like smooth worn river rock, but it would be nice if it wasn't all jagged edges.
    The rock is all in our backyard close enough to the garage that I can reach with tools -- first thought is maybe an air hammer w/ chisel might work, but I figured I'd reach out to others to see if anyone knows of a better option.
    Examples of some of the rock:
    K&K
    Reputation: ki5ka's Avatar
    stone carving
    You might have better luck than you imagine simply smashing the edges with a maul.
    This might be a bit of a stretch but you might get some ideas here. https://forums.mtbr.com/trail-buildi...s-1048175.html For what you have in mind, a cold-chisel will work as will a masonry bit, reground with a diamond stone to a chisel shape. Of course you could also order proper stone carving chisels. Here is a link https://trowandholden.com/all-products/
    If money is no object, then https://stonesculptorssupplies.com/p...matic-hammers/ I think a pneumatic chisel would do the job famously but it's a bit expensive but then again, you might get inspired and become a stone carver .
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    hammer and chisel
    or cement mixer and time...but them rocks you show may kill the mixer
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by 127.0.0.1 View Post
    that'd be one helluva rock tumbler. might wake the neighbors.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Quote Originally Posted by Harold View Post
    Haha like putting steel toed boots in a hotel dryer.....
    Sent from my SM-G960U using Tapatalk
    WillWorkForTrail
    Jun 2012
    The simplest way might just be to use a light hammer to hit the sharp parts straight on. Be sure to wear safety glasses and use a hammer designed for hitting hard things like that - something like a masons hammer - about $25 at Lowes for an Eastwing.
  1. Powder Coat Thinning on Edges
    By Clockwork Bikes in forum Frame Building
    Last Post: 05-25-2013, 11:58 AM
  2. Bend Trail Recommendations - NO EDGES!
    By Metamorphic in forum Oregon
    Last Post: 05-13-2013, 05:51 AM
  3. 12mm rear hub serrated edges - smoothen?
    By Aresab in forum Wheels and Tires
    Last Post: 11-27-2012, 07:29 AM
  4. Why do most disc rotors come with ridged edges?
    By Waspinator in forum General Discussion
    Last Post: 08-15-2012, 11:13 AM
  5. Trim fat everywhere? Or just the edges?
    By Thorin_2 in forum Weight Weenies
    Last Post: 05-30-2012, 12:12 PM
Members who have read this thread: 49
