Quick/easy ways to tread a flat corridor?- Mtbr.com
Results 1 to 7 of 7
    Reputation: fully's Avatar
    Sep 2004
    New question here. Quick/easy ways to tread a flat corridor?
    We've just finished clearing/mowing a 1.5-mile corridor for nearly-flat, riverside singletrack, and I'm wondering if anyone has tips for speeding up the tread development -- aside from heavy raking along the whole segment...
    'Ride it a lot' seems obvious. What else?
    Note that herbicide and motorcycles are not going be on the list of options...
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    If it is ridable, start using it.
    Reputation: 9.8m/s/s's Avatar
    Define heavy raking. Have you raked it at all? Raking it once with a metal rake should make it good to go. It will take about twice the time it would regularly take to walk that distance, which isn't too bad.
    If you're worried, get 5 or 6 friends and put in 10 miles back and forth.
    I call for a mandate to allow only road bikes on trails to limit our speeds and increase our line picking skills-FB
    Don't worry, be happy!
    Reputation: formica's Avatar
    tamp it with the flat side of a McLoed? That ought to keep you busy for a while.
    Have a giant group ride or mini fat tire fest. Just invite a bunch of mountain bikers to use the trails, they will get bedded in after the event.
    Michael Vitti
    CLIMB President
    www.CLIMBonline.org
    www.IMBA.com
    NY State Trails Council Member
    We used a sod cutter. It made a perfect .6 mile single track. We then used the cut sod to repair erosion areas.
    I need skills
    line trimmer/weed wacker. trim right to the dirt.
    good luck.
