mud crossing, clean it up?- Mtbr.com
Results 1 to 8 of 8
    Hi all, crossing a ravine today and came across this mud pit. Would you fill in with rock (flat shale) or leave it? This crossing is usually frozen in winter and dry in summer. This is typical in spring. I had filled it in with the flat shale a few years ago so it was a dry crossing even when wet. A week later the rocks had been removed and it was back to mud. The approach from either side is moderately steep and climbable coming out. Most of our mud is sticky awful, gumbo, clayish, stay packing, sticky, heavy mess. But this spot is relatively non-offensive. I am more concerned about erosion.
    So, should I fill it in again??
    Thanks, MikeB
    K&K
    Reputation: ki5ka's Avatar
    Quote Originally Posted by WMBigs View Post
    Thanks, MikeB
    Always a bummer when people undo thoughtful work. I have permission to do work on the trails from the Land Manager, but no authority beyond that. For me, if someone undoes my work, I leave it be; it has proven unproductive to start a war. In fact, I have pretty much stopped doing all work on our local trails because of the push-back. Not that I don't understand the urge to step into it swinging! lol
    Single(Pivot)and Happy
    Reputation: Boulder Pilot's Avatar
    If it's not your property then you do not have the right to change anything. Contact the land manager and discuss the issue with them, see if they intend to deal with the issue, maybe offer a solution.
    The suspension of your bike sucks if it's different than mine. Really. It sucks. Big time.
    Hitching a ride
    Reputation: Schulze's Avatar
    Feb 2007
    Bigger rocks. Rocks big enough that when a troll sees it they say, "fk that sht!" and keep going.
    Reputation: roughster's Avatar
    Dec 2017
    I'm actually impressed your community is clearly keeping to the tenant of not widening the trail. That's pretty consistent usage pattern through the middle. If this was local in Norcal there would be at least two braids around it by now I gather from the context that this trail is several years old. Given that, and your picture above, I would say erosion seems pretty in control. Maybe let that decide your action. If you start to see it really rut up or people start to braid around it, then maybe it is time for action, but as it is now, I would say leave it be.
    2020 Turbo Levo Comp
    2019 Strive CF 8
    2018 Farley EX 8
    Easiest thing might be to dig out the lower side a bit so the water drains off instead of puddling in the trail and take the trail down just a bit lower so the water is channeled into a narrower path. Any extra soil you dig up can be put back in the trail on either side to raise the tread. Then perhaps the trail will drain better and dry out quicker. From the way it looks, that might not work and it would probably have to be redone every year, but it would just take a few minutes.
    You have permission to do trail work? Looks like you have some seasonal spring water moving across. A buried culvert would work. 6" or so. I'm a fan of big ( trashcan lid sized) flat rocks spaced apart so the water can move through.
    Rent this space for $
    Reputation: Oh My Sack!'s Avatar
    Hard to tell from the pic. Is there ANY side slope to that spot? It appears flat and if it is, it won't drain and you're relying on evap. Importing a natural surface and raising that segment with a nice gradual transition on either side would make sense based on assumed conditions.
  1. To Clean or Not to Clean
    By Canaan in forum General Discussion
    Last Post: 04-22-2014, 05:42 AM
  2. Mud, mud, and more mud.
    By Flying-Monkey in forum Riding Passion
    Last Post: 05-13-2012, 05:43 AM
  3. Post-Mud Grinding Sounds: How to Clean?
    By SWriverstone in forum General Discussion
    Last Post: 05-16-2011, 11:22 AM
  4. MUD MUD MUD AND MORE MUD-Angles camp race report
    By togaman in forum California - Norcal
    Last Post: 04-25-2007, 11:07 PM
  5. Mud Mud Mud Mud
    By XCBob in forum Pennsylvania
    Last Post: 06-25-2004, 02:49 PM
