Massive downed trees with root plates- Mtbr.com
Results 1 to 8 of 8
    Feb 2017
    Have three large downed trees on my local trail, all 2.5 - 3+ ft in diameter. Two with the root plates at 90 degrees, one at 60 degrees hung in the fork of another tree. Have no idea what to do with the hung tree, scares the crap out of me (maybe re-route the trail). The other two pretty sure I can remove, but I've never released a 20' root plate. Any tips or advice?
    WillWorkForTrail
    Jun 2012
    Sawyer training. Tree work is dangerous. Training will give you the know how to deal with such things, and understand whether you want to mess with it or not.
    Apr 2005
    I think if I were you I'd just re-route.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Or at least reroute until such time as you have the resources to deal with
    big trees.
    I ride with the best dogs.
    Feb 2017
    Quote Originally Posted by bsieb View Post
    Or at least reroute until such time as you have the resources to deal with big trees.
    Yes, will probably re-route for now. It will take me at least a few weeks to get the two that are not hanging. May only get one if I don't figure out a way to release the biggest one lying 4' off the ground at the root ball. Not much time left before it will be too hot and humid to ride.
    Feb 2017
    Quote Originally Posted by Cotharyus View Post
    Do have some training, and enough experience to know it's pretty risky. Think I'll try to find someone with more experience than me, if nothing else to confirm that I should just let it be.
    I need skills
    I had a down 10" tree with a relatively small root ball, approx 2' across. I made my first cut approx 15' from the root, cut through, and the tree flipped upright. Where is still stands. I have a 15' tall stump.
    Scared the heck out of me.
    WillWorkForTrail
    Jun 2012
    Quote Originally Posted by sapva View Post
    Kudos. This is exactly what I mean. Iíve attacked situations like this before. Sometimes a cut some distance from the root will allow the tree to stand back up, leaving you a stump. Other times it just lays there. Sometimes Iím lucky enough to have a mini-X handy to fix it. Other times, yes, rerouting is not just the fastest, but also the easiest, and the safest.
  1. uphill obstacles- root ledges and rocks, downed trees
    By mychel0620 in forum Beginner's Corner
    Last Post: 11-06-2016, 09:14 PM
  2. Richmond Hill downed trees
    By Mike Brown in forum North & South Carolina
    Last Post: 04-15-2011, 05:50 AM
  3. Replies: 6
    Last Post: 04-03-2011, 07:57 AM
  4. Demo Trail Conditions with photos of large downed trees
    By phatteus in forum California - Norcal
    Last Post: 04-01-2011, 10:49 PM
  5. Replies: 0
    Last Post: 07-31-2007, 08:22 PM
