Made this bridge today- Mtbr.com
Results 1 to 15 of 15
    Apr 2018
    I needed to connect my west woods trails to my east woods trails so I built this this afternoon using a living tree that had fallen over a long time ago. I slightly flattened the top of the log to attach boards.
    Pretty happy with what I got done.
    Attached Thumbnails Attached Thumbnails Made this bridge today-img_20180421_184202-1125x1500.jpg
    Apr 2018
    I forgot to take a before, but here it is shortly after I started.
    Attached Thumbnails Attached Thumbnails Made this bridge today-img_20180421_153602-1125x1500.jpg
    Nice work! I like the little bump in there, keep it spicy.
    Hitching a ride
    Reputation: Schulze's Avatar
    Feb 2007
    So let's say in 2 years you come blasting across it and the tree gives way because it has been the main course for a million termites. Do you get cell phone service down in that creek bed?
    Dec 2017
    Nicely done!
    Apr 2018
    Thanks rustpuddle and sparkman. Schutze-The tree is still living, just laid over. Fresh spring leaves are popping out now.
    Hitching a ride
    Feb 2007
    ok, then that's pretty neat. A self repairing bridge!
    Any questions?
    I try to avoid sexual innuendo, but its hard.
    Boards seem thin, using pressure treated?
    Mar 2016
    Salvaged pallet decking?
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    How did you fasten the boards? Since they are cantilevered a bit they may want to work loose, hopefully not split. If you predrilled 3/8" holes and used 1/4" timberscrews you the man!
    I ride with the best dogs.
    Apr 2018
    Yes to pallet scraps. Attached with good spiral nails. Might come back with screws if they get loose. My wife and I walk it often too so it gets inspected in between rides. Going to load up some other stuff I'm working on.
    Apr 2018
    Other trail work on my edge of swamp loop. Going to double up the width of the ripped log bridge but I forgot the chain saw file that day and stopped ripping once it got dull. Gotta go back and finish that one.
    Attached Thumbnails Attached Thumbnails Made this bridge today-img_20180419_192955-1125x1500.jpg
    May 2018
    Very cool! how did you flatten the top of the log for the bridge in the first pic?
    Apr 2018
    Thanks. I did it like you would hew a log into a beam. Cross chopped notches to the depth necessary then split them off. Was harder doing it on the top than on the sides like normal when juggling/hewing.
  1. US made vs made elsewhere (with a twist)
    By dv8xin in forum Bike and Frame discussion
    Last Post: 03-29-2013, 03:02 PM
  2. Replies: 7
    Last Post: 07-16-2012, 08:55 PM
  3. Replies: 38
    Last Post: 11-05-2011, 06:09 AM
  4. Demo Forest today, Sunday. 10:30 at bridge.
    By fc in forum California - Norcal
    Last Post: 10-12-2011, 08:02 PM
  5. Non-custom made steel frames made in the US?
    By bwheelin in forum Bike and Frame discussion
    Last Post: 04-03-2011, 01:11 PM
