Gorilla Snot?- Mtbr.com
Thread: Gorilla Snot?
    Gorilla Snot?
    There are several downhill and park style flow trails I'm working on that are built in areas with poor soil. I'm planning on using turfstone to address rutting in some of the jump landing areas.
    My other thought is using soil binders. Wondering what experience builders have had using Gorilla Snot? Can we mix it in with a tiller and compact it? How long will it hold up without maintenance? Does it need regular watering which is a problem since we don't have access to water? Any input would be greatly appreciated!
    Reputation: CactusJackSlade's Avatar
    "Gorilla snot" I have seen used where we ride on the road areas... we managed to get them to put a little down on our start/finish area. It works pretty good...
    It pulls moisture in from the air (in the cooler damp mornings) and holds it. Even if you do not have access to water it works pretty well.
    I did hear it can be expensive though... smells kinda bad when you first put it on. There are different types/brands too apparently.
    All that being said if I were to have access to it on all the trails we use, I'd do it if I could....
    Largest NorCal XC Race Series
    http://www.bicyclingevents.com
    http://www.UavTechReview.com
    Best in the West!
    Cactus, Thanks for the input!
    bigger than you.
    Reputation: Gigantic's Avatar
    what about pitching in the landing and rut prone areas?
  1. snot rocket FAIL
    By parkmeister in forum California - Norcal
    Last Post: 01-21-2018, 05:52 PM
  2. DH bike beating the SNOT out of me...
    By Tigerstripe40 in forum Downhill - Freeride
    Last Post: 01-01-2017, 10:26 AM
  3. So, what's up with snot?
    By TigerNightmare in forum General Discussion
    Last Post: 06-29-2016, 02:49 PM
  4. Sandwiches, dawg and snot rockets (vid 2010)
    By M-U-M in forum North & South Carolina
    Last Post: 07-12-2011, 03:52 PM
  5. Drop Bar Gorilla...
    By PanFry in forum Surly
    Last Post: 01-20-2011, 04:51 PM
