Erosion Permits- Mtbr.com
Results 1 to 11 of 11
Thread: Erosion Permits
    Thinking about riding.
    Dec 2014
    Erosion Permits
    Anybody have any silver bullet for tackling the erosion permit issue with land managers?
    In my state we cannot disturb more then 5,000 square feet without an erosion control permit and plan, which is costly and time consuming, so we have to explain that we will only work 5,000 square feet at a time and remediate it before moving on to the next section (which is fine), but even this plan takes a little convincing... Currently waiting to hear if the 'engineers' accepted this or not.
    Anybody have any other input on how others have shown the land manager/local municipalities that erosion control permitting isn't necessary for trail building?
    WillWorkForTrail
    Jun 2012
    I dealt with this on a project one time. I was using an excavator so they were like no way you're disturbing less than 5K square feet before you remediate. So I took one of the primaries for the property out to another project and showed them - a three foot wide disturbance, opening a max of 500-1000 feet per day, cleaning up right behind it, and done before moving on with the excavator. He looked at me, as though he'd arrived at a conclusion all on his own, and as if I didn't know it, said to me, you never have 5K square feet of ground disturbed at once, we don't even need an erosion permit or plan. We don't even need to budget for fence. You're fine.
    See how handy Jedi mind tricks are?
    Dec 2013
    Quote Originally Posted by TheDwayyo View Post
    What state? Are talking about an NPDES/SWPPP?
    Dirt Monkey
    How much trail do you plan on building at one time? At 2' width, that's ~0.5 miles of trail; which is a significant amount if hand building. Sounds like this should only apply to larger projects (like building a parking lot).
    Reputation: Bluegrassbiker's Avatar
    May 2013
    We run into this often. We never have any luck showing that erosion control permitting is not needed. We are able to avoid having to install wattles or silt socks on the entire trail build by proving we are remediating our daily disturbance. We still have to wattle when working near blue streams, wetlands, and other areas as determined by the permit.
    Wish I had a silver bullet for you. If you find one, please pass along.
    Dec 2014
    Quote Originally Posted by Cotharyus View Post
    Luckily so far we have just explained it, not had to show it, but it does seem like some land managers used to more traditional construction types have a hard time wrapping their heads around it. Glad to hear showing them in person was all it took.
    Quote Originally Posted by CycleKrieg View Post
    MD. Don't know what those abbreviations are so I'm guessing no.
    Quote Originally Posted by aero901 View Post
    Building nearly five miles of trail in this project, the majority of it being done by a contractor with a mini-ex.
    Quote Originally Posted by Bluegrassbiker View Post
    Cotharyus' post pretty much lays out our silver bullet. When I posted this I wasn't sure it was going to be accepted by the current project's land manager - but now it seems that it has. This has been fairly standard with trail projects in this area, though each new land manager takes a little 'education' to get on board.
    If you never have 5k square feet disturbed, you shouldn't need a permit.
    beater
    Reputation: evasive's Avatar
    Feb 2005
    Actually, it's very likely that it was a NPDES stormwater permit issue. State implementation varies across the country, and I don't know about Maryland. I'm glad that you found this resolution. I know some trail builders have had to comply with stormwater construction permitting, but (speaking as someone who works in the field) I think that's nonsense. Since stormwater runoff from forest roads can't be regulated under the Clean Water Act, it seems silly to regulate nonmotorized trail consruction.
    Dec 2013
    Quote Originally Posted by evasive View Post
    Actually, it's very likely that it was a NPDES stormwater permit issue. Since stormwater runoff from forest roads can't be regulated under the Clean Water Act, it seems silly to regulate nonmotorized trail consruction.
    A NPDES permit is for construction or extraction activities. Not existing road ways. Each state's implementation is slightly different, so never assume you aren't required to do one, regardless of what the land manager tells you. Ask the appropriate agency in your state. Many states consider a total project impact, not the area being worked on. The total area de minimus us usually 1 acre.
    https://www.epa.gov/npdes/stormwater...ion-activities
    A SWPPP is the actual document that lays out how to actually prevent any discharges. Its a description of what steps you will be taking to keep the work area as stable and erosion free as possible.
    https://www.epa.gov/npdes/developing...ion-plan-swppp
    When working, use duff raking/replacement to spead up vegetation regrowth.
    beater
    Feb 2005
    Whether or not forest roads (including construction) are subject to NPEDES permitting was the subject of a significant lawsuit earlier this decade. It ended at the Supreme Court. I was writing TMDLs at the time and we followed it closely. After that the 2014 farm bill revised the CWA and clearly specified the silviculture exemption. It explicitly excluded forest road construction from permit requirements. Hence my opinion that if forest roads arenít subject to NPDES requirements, it seems silly for non-motorized trails to be.
    https://www.govinfo.gov/content/pkg/...2016-15844.pdf
    Yes- most states have ďcommon plan of designĒ language or similar in their rules, so regardless of area disturbed at any one time, the total project area is what determines the permit requirements. But trail construction is different than what most people think of as construction. There isnít much that needs to be stabilized or revegetated- in many cases the disturbance is the finished surface and itís surrounded by hundreds of feet of vegetated buffer. Itís kind of stretching the law into an unwarranted activity and it can be an awkward fit. Iím certainly not a stormwater expert but I do administer a water quality permit program. Not NPDES, but a sister program modeled on it. I definitely agree that you should always call the regulator to see where you stand- my opinion doesnít influence whether your permitting authority determines that you need a permit. I take those calls almost daily.
    Dec 2013
    Whether or not forest roads (including construction) are subject to NPEDES permitting was the subject of a significant lawsuit earlier this decade. It ended at the Supreme Court... I definitely agree that you should always call the regulator to see where you stand- my opinion doesnít influence whether your permitting authority determines that you need a permit. I take those calls almost daily.
    That was an interesting read. Am a reading it correctly that its just forest roads established for logging related activities?
    MN is requiring a SWPPP for any disturbance over an acre. That includes trails as any trail over 2 miles (4ft x 11,000ft = 44,000sq.ft.) would meet that requirement. I know that trails for ATVs and snowmobiles are required to do the same, as I'm filling out a SWPPP for an ATV trail at work. So I'm surprised forest roads wouldn't be included.
    beater
    Feb 2005
    I havenít done a deep dive into whether the roadís purpose has to be considered in order for the statutory exclusion to apply, but I think that would be very hard to implement.
    For the reasons I mentioned above it seems silly to me to apply the law to trail construction, but I can see how a strict application would lead someone to require it.
    Agriculture has always been considered a nonpoint source under the CWA, so it probably wasnít a huge stretch to argue that silviculture is similar and should be too. Weyerhaeuser has more friends in congress than Trail Solutions. That sounds cynical, but I agree with the decision. Road sediment is handled well by BMPs and voluntary efforts, at least by the USFS in this Region. And Iíd say the big private timber company here does pretty well, too.
  1. Do guide stones actually cause trail widening? and erosion? make trails unsustainable
    By BushwackerinPA in forum Vermont, New Hampshire, Maine
    Last Post: 07-12-2016, 06:36 AM
  2. Sissy lines and good erosion
    By Snototter in forum North & South Carolina
    Last Post: 04-18-2016, 10:02 AM
  3. Erosion-loving purists versus dirt-packing DJ/freeride rehab....
    By cmc4130 in forum Trail Building and Advocacy
    Last Post: 10-28-2013, 08:03 AM
  4. Does trail erosion really harm the environment?
    By TwoHeadsBrewing in forum Trail Building and Advocacy
    Last Post: 04-10-2013, 07:47 PM
  5. Napa Skyline erosion control
    By impact23 in forum California - Norcal
    Last Post: 09-19-2011, 09:30 AM
Members who have read this thread: 81
