building signs in rocks- Mtbr.com
Results 1 to 9 of 9
    Reputation: boostin's Avatar
    We need to erect a few signs but the extremely rocky terrain prevents us from getting anything to stay up.
    We are looking at a few options but I was wondering if any others had come up with anything clever to handle this situation. We were talking about building a mount for the post on a steel plate and just leaving it on the surface, with a few rocks on the plate.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    "We were talking about building a mount for the post on a steel plate and just leaving it on the surface, with a few rocks on the plate."
    This is exactly what I was going to suggest when I first started reading your post.
    Honestly... ahh I give up
    Terrain Sculptor
    Reputation: Trail Ninja's Avatar
    got any solid rock? You can drill and put in rock or concrete anchor bolts for a more permanent solution. It's a lot of work though, if your rocks on a plate solution will suffice.
    Quote Originally Posted by Trail Ninja's Son
    You may be happy to hear that my dad has kicked cancer's ass. Now he's looking for whoever sent it.
    Jan 2005
    Agree with Ninja, you can fasten with some type of anchor bolt or use a bolt and secure it with epoxy.
    If you have a dead flat surface on like a piece of shale i suppose you could glue a thin aluminum sign to a large rock and prop it up.
    ....~|____\
    _____||_________
    .\....FAILBOAT..../
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    I have done a lot of drilling and mounting in solid rock, usually a sign or figure with a 3/4" solid steel rod mounting pin. 1000 watt generator, 5/8" SDS hammer drill with 1" x 12 SDS bit, Caulk gun with 2 part rebar epoxy, tire pump with chuck removed to blow dust out of the drilled hole. I carried it all in a BOB trailer. Not too hard once you have all the stuff assembled. The pics are from 2006.
    Attached Thumbnails Attached Thumbnails building signs in rocks-dsc_9431-copy.jpg
    I ride with the best dogs.
    Stencil and spray paint?
    Lots of credit to bseib for extrem effort, but I had to crack up when I read that one followed by the simplicity of simterfex's suggestion.
    Ride da mOOn Moderator
    Reputation: NEPMTBA's Avatar
    Wink
    Rock karns pile...
    ... glued together with construction adhesive with a wood sign on top of it!
    Rocks have to be dry for glue to stick, larger rocks on bottom and progressively as they go up. Provided you have rocks that will co-operate.
    bsieb, that is badass.
    Thanks for the ideas. I am going to mull this over with my partner in crime.
  1. Replies: 3
    Last Post: 06-02-2008, 10:35 AM
  2. Castle Rocks SP/ City of Rocks
    By tracyclifton in forum Idaho, Montana, Wyoming
    Last Post: 02-22-2008, 04:11 PM
  3. Trail Building in Glen Major (3 Rocks) Oct 27th & 28th
    By jmurray in forum Eastern Canada
    Last Post: 11-05-2007, 09:40 AM
  4. Replies: 0
    Last Post: 12-27-2005, 03:55 PM
  5. How long until Hartman Rocks actually rocks?
    By Fischman in forum Colorado - Western Slope
    Last Post: 04-22-2005, 09:25 AM
