Results 1 to 20 of 20
    Jan 2019
    Stuck crank arms
    I am trying to convert my wifeís specialized Jynx to a 1x and canít get crank arms off. I am using the correct crank extractor. Park Tool CCp-22 but cannon get the cranks off. I am lookin gape some tips on what to try next. I even tapped the crank extractor with a rubber mallet.
    Attached Thumbnails Attached Thumbnails Stuck crank arms-e9d8b725-d96c-411d-b1d3-4c66f0015c1f.jpg
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    You just gotta man up and turn it. The spindle is tapered, so once you break it loose, it'll come right off.
    Bicycles donít have motors or batteries.
    Ebikes are not bicycles
    Oct 2018
    That crank isn't a self-extracting crank? I don't have enough experience in bicycle repair, but how common is it to require a crank extractor on a modern bike?
    Regardless -the self-extracting system for the 2016 FSR requires crazy effort. I use the handle from my floor jack as a cheater. The opposing crank should be secured somehow. Then use all the big muscles.
    It's hard to fathom the loosening force required for a bolt tightened to about 46lb-ft.
    If your bike is anything like mine, there is no way that short handle is going to do the job.
    Ditch the handled extractor and buy a CCP-7 (aka universal puller). Use it with a ratchet handle, and grab the crank arm with the same hand (a la scissors). It will come off with little fanfare.
    Jan 2019
    I have now stripped out the threads on the crank arm and it is still on the bike. I used some extra leverage. Not sure what to do next.
    SS Pusher Man
    Sep 2001
    Quote Originally Posted by Forest Rider View Post
    A lot of entry level bikes still come with square taper bottom brackets. They do not come with self extracting bolts. You have to use an extractor.
    SS Pusher Man
    Sep 2001
    Quote Originally Posted by jmoore981 View Post
    Sounds like you didn't have the tool threaded all the way in. Did you strip all the threads or just the outer threads?
    Reputation: Lone Rager's Avatar
    Dec 2013
    If puller threads are totally stripped, you might find a gear-puller than will work. With stripped puller threads, you need new crank arms anyway. ...or cut the spindle behind the crank arms and replace the bb. Cartridge BBs are like $25.
    Do the math.
    #6 Jacobs Chuck Wedges can be banged in behind the crank arm, over the spindle. They will remove the arms without damaging them. Use a long-nose punch to hit the wedges together past the chainrings. You can use a large C-clamp to close them together, if you have access to one (6" throat, or so).
    Watch a few videos on how to remove chucks from drill presses. It's the exact same procedure.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Cut it off and buy a cheap set of slx's.
    Reputation: J.B. Weld's Avatar
    First, make sure the extractor is screwed into the crankarm tight, use a wrench. Then just go for it, when the tool hits the spindle you have to put some meat into it. Use a cheater bar if necessary.
    I brake for stinkbugs
    Quote Originally Posted by Lone Rager View Post
    If you're going to cut anything, make it the crank arm, you'll be replacing that anyway, and it's a lot softer metal than the spindle.
    Jan 2019
    Thanks for the advice
    Dec 2013
    ^^^ turn the bike upside down and it's easy and straightforward to get at the spindle and cut it with a hacksaw. To cut the crank arm off the spindle, you need to cut parallel to the spindle, which is more involved.
    With the wedge method suggested above, the wedges go between the arm and the face of the BB. As long as the face of the bb doesn't get disrupted too badly, this can work.
    Do the math.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    put the bolt in loosely, one thread less than finger tight at most
    then go for a nice stomping ride. it should wiggle the crank loose eventually if you crank up some hills. do some laps...crank should loosen eventually but not fall completely off....
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Life's a ride, enjoy it! Moderator
    Reputation: life behind bars's Avatar
    May 2014
    Engage the extractor and put some ass in it. If it still refuse to budge, whack the side of the crank arm with a soft faced hammer. Rinse, repeat.
    Wanted, SRAM GX 2x11 rear derailleur
    It ain't supposed to be easy.
    Quote Originally Posted by life behind bars View Post
    I also skimmed the part where the op said he stripped the threads. Like mtnbikej said the tool must not have been screwed in all the way.
    All the ways mentioned will work. A cordless bandsaw would make quick work of it.
    May 2014
    Quote Originally Posted by J.B. Weld View Post
    A Portaband would be the path I would choose as well. Slash and burn !
    Jan 2019
    Good news is I was able to remove drive side! Had to use more mussel than I thought I had.
    I think I had it threaded all the way in on non drive side. Probably going to try to use a punch and see if that works before I go to the hacksaw.
    Attached Thumbnails Attached Thumbnails Stuck crank arms-b7118f9d-efa1-4d66-b857-11ed17e6df14.jpg
    Jun 2017
    Put the drive side back on and take it for a decent ride. Should pop right off after some good hard pedal strokes.
  1. Pedals stuck in crank arms, wont break loose.
    By dirtrider76 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-17-2015, 09:01 PM
  2. Crank Arms Stripped - New Arms or Crank?
    By mikelikebike in forum Beginner's Corner
    Last Post: 06-08-2008, 06:21 PM
  3. Crank arms stuck
    By RebaRox246 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-04-2008, 03:34 PM
  4. My arms! My arms!
    By JBone in forum Singlespeed
    Last Post: 10-26-2004, 08:18 AM
Members who have read this thread: 62
