Results 1 to 9 of 9
    Stone Jack Baller
    Reputation: slowpoker's Avatar
    Star nut removal, or...
    Hello!
    So, I'm in the process of rebuilding my wife's bike. I got a fork that has never been mounted on a bike, but the steerer was cut. It's the right length, but they had already installed the star nut. I have a hope headset to install with head doctor. Is there a way to remove the nut, or should I push it down the tube? The hope cap screw fits the star nut. Should I consider using the star nut with the hope headset, or does that sound like a bad idea?
    Reputation: flipnidaho's Avatar
    Drill out the center of the star nut.
    Stone Jack Baller
    Sounds simple enough. Thanks!
    Class Clown
    Reputation: dundundata's Avatar
    you can always push it down and leave it in there
    Reputation: gmats's Avatar
    Apr 2005
    Or, install a top cap and get a spare steel bolt. And just keep tightening down on the bolt which will pull the star nut up. When it's close to the top, you can pull on it with vise-grips or something by rocking it back and forth.
    If you're lucky, while you are pulling it up, it'll just bend enough that it will come right now.
    Class Clown
    I would rather knock it down a bit than try to pry it out the top and mar up the inside of the tube
    Reputation: mfa81's Avatar
    Quote Originally Posted by flipnidaho View Post
    this...
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    Yeah, they can be tapped downwards and out much easier than they will move up - which is the sort of force they are designed to resist. You can tap them out with a good sized wooden dowel, or similar.
    Less isn't MOAR
    Plays with tools
    Reputation: customfab's Avatar
    Why not just use the star nut? They've been working really well for a decade now.
  1. (MkIII) Star Nut Removal
    By Speedub.Nate in forum Shocks and Suspension
    Last Post: 04-25-2012, 09:22 AM
  2. DT Swiss Star Nut Removal
    By mtbnozpikr in forum Wheels and Tires
    Last Post: 08-20-2011, 07:13 AM
  3. how to keep star nut from pulling out?
    By gbosbiker in forum General Discussion
    Last Post: 02-07-2011, 12:15 PM
  4. How do you remove a star nut successfully from a steerer tube?
    By sasquatch rides a SS in forum Tooltime
    Last Post: 01-14-2011, 02:17 PM
  5. Do new forks come with star nut??
    By EvanSpikes in forum Shocks and Suspension
    Last Post: 01-08-2011, 10:10 AM
Members who have read this thread: 4
