Results 1 to 7 of 7
    Jul 2017
    source for 410/4xx alloy stainless bolts (aka magnetic stainless steel)
    Hi -
    I need a number of magnetic bolts for bike related projects. Obviously everything is subjected to the elements.
    I've searched everywhere i know of (including mcmaster.com and Tacoma Screw) for a 400-series alloy stainless steel metric socket cap screw. Unlike the 300 series bolts these should have strong magnatism as well as (decent; worse than 300's) corrosion resistance. Corrosion resistance should be much better than zinc'd steel, though.
    Do you have any ideas where I could find this? Obviously this is typically an industrial product and on 'industrial' scale I'm very low volume.
    May 2017
    McMaster Carr has them. They call it Nickel Alloy
    Jul 2017
    Quote Originally Posted by Kolchak View Post
    Huh. I'll try them again. I emailed them asking for any 400 alloy; it would be odd if their customer service didn't know what that was.
    Jul 2017
    Quote Originally Posted by high_desert_mud View Post
    Ok, i found their product page. https://www.mcmaster.com/#96146a157/=19egkek ("nickel alloy socket head screw") clicking through one size, it says "400 Nickel", and "mildly magnetic"
    I'm a little confused; my understanding was it is nickel, primarily, which changes the room-temp stable crystal structure of the alloy to one which is not magnetic; and 400 series alloys differ from 300 series by the zero or lower nickel. Also I was under the impression that had generally less corrosion resistance than 300, not more as the Mcmaster listing states.
    May 2017
    look here
    https://www.mcmaster.com/#standard-s...crews/=19egqzi
    The Nickel alloy are actually monel which is slightly magnetic not 400ss sorry.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Jan 2015
    look here
    We use Monel all the time here at work. Great corrosion resistance (particularly to salt water), pretty high tensile strength, but generally soft and fairly prone to gauling. Not my idea of an ideal fastener material.
  1. Replies: 0
    Last Post: 03-09-2016, 01:59 PM
  2. Chainring Bolts - Stainless vs Aluminum, / Locktite vs Lube
    By Scott Novak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-11-2013, 01:09 AM
  3. Geax AKA 2.2" F/R or AKA (R) + Segauro (F)?
    By Pelly_NH in forum Wheels and Tires
    Last Post: 02-10-2013, 04:43 PM
  4. Stainless, Stainless, Stainles....
    By Mark42 in forum Mongoose-Schwinn
    Last Post: 08-08-2012, 12:46 AM
  5. Replies: 7
    Last Post: 10-22-2011, 04:52 PM
