shock pump help- Mtbr.com
Results 1 to 3 of 3
Thread: shock pump help
    shock pump help
    Just bought my first FS, with air shock on both. Marzocchi MX Comp w/eta, and Fox Float R. I'd like to get 1 pump that can handle both. Marz. doens't recommend using a rear pump(300 psi?) on a front fork. Can anyone comment on this, and/or recommend a good pump for my purpose?
    Thanks folks.
    I use the same pump on both (same fork and rear shock) with no problems. You'll need an adaptor for the marz, and I can say it is a bit cumbersome trying to get the exact PSI on the fork, as it is so low, but you can do it...
    I'm not a big fan of air forks after trying a coil, but my experience is that you can set the marz and forget about it, it won't leak at all.... Once you have it set, DON"T touch it if there is not a problem....
    I think my front is fine, just need some air in the rear. Since you say they don't leak, maybe I'll just head over to the shop and get it done. Thanks.
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. K2 Razorback Noleen Mega Air rear
    By MegaVolt in forum Shocks and Suspension
    Last Post: 03-30-2004, 09:28 PM
  3. shock pump 4 '02 Mrzcch marathon 80
    By stoked in forum Shocks and Suspension
    Last Post: 03-25-2004, 02:08 PM
