Seatpost Clamp stuck need help...!- Mtbr.com
Results 1 to 5 of 5
    Reputation: neurowerk's Avatar
    Hello dont know how many of you guys encounter this but my seat post always keep on dropping down and I keep on tighten it and now I have screw it up the secure seat bolt is wash out cant remove it. Any suggestion how to take out the bolt?
    Old man on a bike
    First, try using visegrips if the bolt is already
    ruined, they should get enough of a grip to loosen the bolt (and hold the other end steady with an appropriate tool if possible). You might make sure your seat clamp next is the correct size, or that your seatpost is the correct size before you replace the bolt. What materials your seatpost/seattube are made of might be a factor in the slippage; the amount of grease you're using might be a factor too.
    suum quique
    I think the best way to solve the problem is to change the seat post the seat clamp currently the seat post provide by Scott is not that good and due to my body weight that one of the reason why the seat clamp unable to hold the seat post. Do you have any recommendation for the seat post and the seat clamp?
    Reputation: Dartman's Avatar
    New post? One word...Thomson
    Mike
    Hope Thompson will solve my problem..... :(
    Because of my body weight, that's one of reason why seat clamp cant hold I am trying very hard to lose weight. How many of you out there have the same problem I encounter due to body weight and the seatpost keep on dropping..?
  1. What size seatpost clamp do I need?
    By Coldfire in forum Downhill - Freeride
    Last Post: 09-14-2004, 12:22 PM
  2. How to keep saddle from sliding in seatpost clamp?
    By Adirondack Blues in forum General Discussion
    Last Post: 07-19-2004, 01:45 PM
  3. 03 Dakota XC seatpost clamp size?
    By RZK in forum Jamis
    Last Post: 06-16-2004, 07:18 PM
  4. What size is the NRS seatpost clamp?
    By fatnbald1 in forum Giant
    Last Post: 06-16-2004, 03:45 PM
  5. Creaking seatpost clamp solutions?
    By Jim Beam in forum General Discussion
    Last Post: 05-05-2004, 11:35 AM
