Removing front chainring cassette from spline- Mtbr.com
Results 1 to 3 of 3
    Dec 2004
    does anyone know how i can get my front chainrings (whole cassette) off the spline? do i need a gear puller or waht?
    Gianni
    Currently attending Cal Poly SLO to become an Industrial Engineer.
    Hometown: North San Diego (summertime)
    user-created
    Reputation: singletrack's Avatar
    Quote Originally Posted by SDMiniTrucker
    It's called a "spider".
    I'm assuming your using Shimano cranks, in which case you've gotta pop the lock ring off the inside of the arm, and then use an XTR BB tool to spin off the nut.
    Unless I've misread your question, and you really just need a crank puller....
    If you are removing the cranks, see http://www.parktool.com/repair_help/...dle_type.shtml
    If you are removing the cassette type chainrings from the crank see http://www.parktool.com/repair_help/FAQBBT8.shtml
  1. Smallest front chainring on intense M1
    By partswhore in forum Downhill - Freeride
    Last Post: 12-17-2004, 09:35 PM
  2. freeriding with a single front chainring
    By northoceanbeach in forum Downhill - Freeride
    Last Post: 07-30-2004, 03:53 PM
  3. removing cassette
    By extensive in forum Tooltime
    Last Post: 07-22-2004, 09:45 AM
  4. removing a cassette
    By ajw8899 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-16-2004, 04:33 AM
  5. Is your front chainring Ovalized?
    By fc in forum Singlespeed
    Last Post: 06-11-2004, 01:43 PM
