Recommend a thick, "dry", paste-like grease?- Mtbr.com
    On MTBR hiatus :(
    Can anyone recommend a readily available, temperature stable, paste-like grease? Thicker than Permatex anti-sieze.
    Loose Nut Behind d' Wheel
    Reputation: Lucky's Avatar
    Quote Originally Posted by Speedüb Nate
    There was a guy who used to post here a long time ago who was a fan of Quaker State boat trailer wheel bearing grease. Able to go from under water to highway speeds, and quite cheap at WalMart, KMart or autoparts stores. Would that work for you?
    Kathy :^)
    Look where you want to go. This is as true in life as it is in mtbiking.
    On MTBR hiatus :(
    Thicker, dryer, pastier, less goopy than that?
    Quote Originally Posted by Speed?e
    The only thing that comes to mind was some nasty black molybdenum (I think) grease my ex used to repack the CV joints in his old Rabbit eons ago. It qualifies as thicker, dryer and pastier than that, if my memory serves. It looked like sludge. Unfortunately, I don't remember exactly what it was called.
    Kathy
  1. Replies: 2
    Last Post: 07-19-2004, 08:28 AM
