Problems with shifting- Mtbr.com
    Jul 2003
    For some reason my bike won't shift into a higher gear unless I keep shifting up and even then it won't shift up until I shifted all the way up to the highest gear. I have no problem shifting down. Can anyone offer help? Are there are online guide on how to adjust your front and rear dereailler?
    Old man on a bike
    Besides this belonging in the drivetrain forum
    clarify by what you mean by shifting up into a higher gear. You can't get the chain on the smallest cog in the rear or the largest? Your description seems to say you keep moving your shift lever to one extreme of it's range and only then does the chain actually go there, but not in between? Besides trying to guess what you mean, I'd think you need to either adjust your derailleur cable or clean your cable/housings (or possibly replace one or both). Check out the parktool.com or sheldonbrown.com sites for help on details of workings/adjustments...
    suum quique
    Quote Originally Posted by DaveGT101
    It sounds to me like there's a problem with either the cable or the housing; something's preventing the derailleur from freely pulling the cable when you shift into a higher gear. It could be that the housing is simply dirty (gummed up inside), or it could be due to a frayed cable, or even a kink or unusually sharp bend in the housing. If it's been a while since the cable and housing has been replaced, the easiest place to start is to replace both. If the cable and housing are fairly new, then check the cable routing to make sure there are no kinks or sharp bends. Also check the locations where the cable enters and leaves the housing to make sure the cable isn't frayed.
    Two of the online guides that I frequently use are:
    http://www.parktool.com/repair_help/FAQindex.shtml
    http://www.sheldonbrown.com/derailer-adjustment.html
    Dec 2004
    Idea!
    If you are having problems with your rear derailleur a common step to forget is to check the alignment of your derailleur hanger. If it is too far off center no amount of adjusting the hi/lo screws will make it shift right.
    dan
  1. Problems with shifting on new Trek 8500
    By Appitite4Destruction in forum Trek
    Last Post: 12-07-2004, 06:53 PM
  2. shifting problems
    By struckman@charter.net in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-11-2004, 02:37 PM
  3. Front mech shifting problems
    By Ridders in forum General Discussion
    Last Post: 06-07-2004, 05:31 PM
  4. TIRED of shifting problems
    By Shwaa in forum Singlespeed
    Last Post: 05-19-2004, 02:38 PM
  5. Chameleon shifting problems?
    By Klaus in forum Santa Cruz
    Last Post: 03-21-2004, 11:31 AM
