Results 1 to 25 of 25
    Jun 2017
    Press fit bottom bracket tool?
    OK. I'm going to buy one of these. Just because I don't want to destroy the bottom bracket getting it out.
    Is there a universal tool? Or do I need a specific size.
    Looks like mine is a Shimano BB71-41.
    Thanks for any help!
    Joel in Asheville.
    Reputation: Mr Pig's Avatar
    My bike has one of those. I have no idea how the heck you get it out! Thanks to you, I'm about to find out though ;0)
    Reputation: rx4mtb's Avatar
    Look at the Enduro tool, it's pricy but does really good job.
    What BB will you be replacing it with?
    Apr 2016
    I made a tool to press in headsets and used it last week to press in bottom bracket bearings on an old Fat Chance mountain bike. Under $20 in parts
    Sent from my SM-N920V using Tapatalk
    Reputation: ethierjung's Avatar
    May 2017
    2015 Scalpel Carbon Team/Eagle 1x12
    2015 Scalpel Carbon Team #2
    2017 Stache 7
    2016 Boone RSL
    2016 CAAD 12
    Apr 2013
    I've been happy with the few bits I bought from ebay seller MTB Tools. They are basically nice versions of what a handy person would make at home, but they are priced very reasonably. The various machined bushings I have from him all fit as described.
    Press for BB92, 24mm spindles: MTB Tools BB24 Bottom Bracket Bearing Installation Press Tool | eBay
    Nothing fancy, but the price is right.
    Yes yes yes but how do you get the thing out?
    Apr 2013
    Quote Originally Posted by Mr Pig View Post
    A bearing removal tool like this works well: IceToolz E293 Press-fit Bearing Removal Tool BB bottom bracket bicycle bike B.B. | eBay
    You slide it in until the prongs pop out behind the bearing, then tap the bearing out with a dead-blow hammer.
    The other style is a slide hammer like this: Park Tool BBT 30.3 BOTTOM BRACKET BEARING TOOL Remove BB30 SRAM Press Fit 30 | eBay
    But I've had better luck with the "pronged" removal tools. You can also DIY it by using a sturdy drift to tap on the inside of the bearing, coming in through the opposite side. The problem is that you can't put force on the whole bearing at once, and you don't want to bind the bearing by pushing it out all from one side, so you have to tap, move to another spot, tap, move, tap, move, tap, etc., being very patient.
    Also, with anything pressfit you need to keep a bag of tricks handy for when things get tough - you can use dry-ice to cool the internal bearing to shrink it, you can use boiling water to heat the outer shell to expand it, you can use a dremel with a cutting wheel to put a "crack" in a tight bearing to break it and allow it to be pulled out, etc.
    I have a freezer in my shop (for popsicles), and whenever I'm pressing a new bearing into something I leave it in the freezer for a few minutes to cool it down - it can make the difference between a bastard of a tight fit, and and simple pressing action.
    Quote Originally Posted by phidauex View Post
    So there is no sleeve in there covering the inside of the bearings? I would've thought some kind of spacer tube would be needed in there?
    since 4/10/2009
    Reputation: Harold's Avatar
    There's still a lip of some sort in there. It's the same tool you use to remove headset cups, so that's helpful.
    I bought one of these for installation.
    Professional Bottom Bracket Universal Press
    It's a really nice tool for the job.
    Quote Originally Posted by Harold View Post
    Spiffing. I have one of those.
    since 4/10/2009
    Gotta check the size you have. There are at least 2 sizes (Park has 2). The bottom cup on tapered headsets takes the bigger size, which iirc isn't much good for most bbs.
    Sent from my SM-G900V using Tapatalk
    Mine is home-made. Old alloy seatpost with slots cut. Works, cost nothing ;0)
    since 4/10/2009
    still need to make sure it's the right size for the bb you want to hammer out. needs to be small enough that it fits through the ID of the bearing/spindle hole and it needs to expand enough that it will snap into place on the largest diameter tube you'll be using it against (basically, the inside of the bb shell).
    Yeah, if it doesn't I'll just make another one. Dead simple.
    May 2017
    2017 Stache 7
    2016 Boone RSL
    2016 CAAD 12
    To get it out assuming it's going to be completely replaced, a wooden dowel smaller in daiameter than the crank axle spindle & a rubber mallet.... start hammering. I knocked mine out with a large screwdriver making sure not to hit any metal.
    Pressed the new one in with a headset press. Works like a charm.
    since 4/10/2009
    Quote Originally Posted by eshew View Post
    Probably better to get it out as straight as possible. Your way seems a great way to damage the bb shell of your frame doing it that way often. I know ppl who have scrapped frames with pf shells because replacing bbs frequently (and probably sloppily) eventually makes them fit loose.
    May 2017
    2017 Stache 7
    2016 Boone RSL
    2016 CAAD 12
    Yeah, I've taken bearings out that way very often but it's risky, especially on an alloy frame. Don't get me wrong, I would do it that way if I had to but I've had years of practice. Any method that pushes the bearing out straight has to be preferable.
    Really?! Yikes I guess I'll try and get a bit more sophisticated next time. I was in the process of completely rebuilding a process 153 and assumed my headset tools would work (to big), didn't want to lose any momentum so the screw drivers... Wonder if a bit of old handle bar could work next time...
    Reputation: LarryFahn's Avatar
    Just a heads up, but this isn't a slide hammer either. It still requires a hammer to drive it out. The blue washer on it goes into the opposing side to align the tool so you hit it straight on and don't cause the BB to get crooked.
    Fwiw, it comes with 2 "washers" that are compatible with a headset press. These are used to install an identical BB.
    Ttyl, Fahn
    Hubbard Bike Club
    Oct 2015
    The Park tool BBT90.3 is nice but overpriced ($50 or so).
    The Taiwan equivalent is similar and more reasonably priced ($20 on eBay) - Icetoolz E293.
    Get a 1/2" piece of PVC pipe, four cuts, bend out, and you are done under $1.
    Never limited by common sense...
    Reputation: Lone Rager's Avatar
    Dec 2013
    FWIW: Pressing on the unsupported race when installing or removing pressed in/on cartridge bearings is usually considered damaging to the bearing.
    Do the math.
    Oct 2015
    All these tools do the same thing, they press the fiber sleeve from the inside, I am not sure if any force passes through the bearings pressed in the sleeve, would have to dismantle one to check.
    These BB71 or BB94 Shimano bottom brackets are $20 and $30, so it is rare that anyone would remove and reinstall the same one. The tools main advantage, when compared to the real brute force of hammer and screwdriver, is to eliminate any risk of marring the frame. In that aspect, the $1 PVC one is the best choice, even if you misuse it, it is softer than the frame.
  1. DIY Bearing Cup Press Tool for $5 (Press Fit Bottom Bracket) WITH PICS!!!
    By Poopshute in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-20-2017, 10:01 AM
  2. Replies: 4
    Last Post: 11-16-2015, 10:49 AM
  3. Park Bottom Bracket Press-fit Tool - BBT 90
    By rideronthestorm in forum Tooltime
    Last Post: 12-20-2012, 09:16 AM
  4. Shimano press fit BB92 and GXP press fit BB92 the same?
    By Stryder75 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2011, 04:28 PM
  5. Press fit Bottom Bracket.
    By mudpup in forum Pivot Cycles
    Last Post: 04-01-2011, 10:37 AM
Members who have read this thread: 45
