Results 1 to 8 of 8
    Reputation: babybabe's Avatar
    Dec 2017
    pf41 bearing shell width issue
    After replacing the drive-side Race Face BB with a Hope BB, I noticed bearing doesn't fit flush against the frame. I compared the width Race Face with the Hope and see that the Hope is about 1mm wider. Is there a remedy? Or are there standards for widths for these parts? Def prefer not to go back to using the Race Face if possible. Thanks!
    pf41 bearing shell width issue-img-2247.jpgpf41 bearing shell width issue-img-2248.jpg
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Do you have any spacers installed on the drive side?
    since 4/10/2009
    Reputation: Harold's Avatar
    Doesn't look fully pressed in, for one. There are "standards, but a 30mm spindle in a pf41 shell violates many of them, so don't expect bbs to be identical.
    Sent from my VS995 using Tapatalk
    Dec 2017
    For one, it won't go in any farther. No spacer. The Race Face is 6-7mm; the Hope is 10mm. Clearly I should have measured BEFORE I installed it, but no big deal. Sorry, I've been reading about this stuff and trying to make sense of it for a while. I've not seen anything about widths of the bearing shells, just outside diameter and what size spindles they handle. There's the plastic insert inside the frame. The bearing is hitting that. I'd like that not to be there.
    since 4/10/2009
    Quote Originally Posted by babybabe View Post
    Ah. The Hope bb (and the enduro one that I have - they are the same) do not use the plastic sleeve.
    Dec 2017
    That would be great. I couldn't be certain if that was part of the frame or part of the bottom bracket. Seems a tight fit. How do I get it out? BTW, Harold, I learned a lot over the past couple weeks reading your threads about the Hope/Enduro.
    Dec 2017
    Idiot eureka moment. The sleeve has a lip on the non-drive side, so you can't push it out from that side. But it pushed out from the drive side with just my fingers.
    Thanks, all. I should be good now!
    since 4/10/2009
    good to hear!
  1. Replies: 3
    Last Post: 12-07-2018, 03:36 AM
  2. alternative crankset for PF41-132 (Ice cream truck)
    By high_desert_mud in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-21-2018, 09:41 PM
  3. Hope PF41 30mm BB question
    By scoobiemario in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-14-2018, 09:05 PM
  4. Replies: 14
    Last Post: 03-15-2016, 05:11 PM
  5. Hard shell or soft shell knee pads
    By Qubo_2408 in forum Apparel and Protection
    Last Post: 07-18-2012, 08:43 PM
Members who have read this thread: 27
