Results 1 to 11 of 11
    Park Tool Truing TS-TA Truing Stand Adapter
    How well does the TS-TA adapter work in a Park TS2 type stand. Do hubs center easily in or do you have to mess to get the wheel straight . Does it work better or worse than plug in type adapters like the Mtb Tools ones.
    I currently have 20mm, 15 mm and 12mm hubs, so buying individual adapter for each would be more expensive than the TS-TA.
    I have the both. IMHO The individual adapters work better, are more consistent and easier to use.
    Jun 2017
    My personal choice is the TS-2TA's. They allow for much quicker install and removal. They do require a heavier hand on the upright adjustment knob to securely hold the wheels. The TS-TA is handy as well just not as quick when it comes to truing, cleaning and other adjustments.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Mechs at the LBS simply rest the existing (or a spare) through axle in the V notches of the stand. That's worked for me.
    Do the math.
    Sep 2018
    You might want to check out the truing stand adaptor that Abbey Tools makes:
    https://www.abbeybiketools.com/produ...stand-adaptors
    Reputation: rx4mtb's Avatar
    I like the individual adapters myself, these particularly. The whole set will set you back $28 shipped and they are superior to the Park IMHO.
    Reputation: bvibert's Avatar
    Mar 2006
    Quote Originally Posted by parktool View Post
    TS-2TA is what I use on my TS-2 stand. I've never had any issues with my TA hubs, though it's a bit of a squeeze to get my 142x12 rear hub in. I suspect if I had a TS-2.2 it wouldn't be an issue at all.
    DOOM
    Reputation: silentG's Avatar
    FWIW I have the TS-2TA and the mtnbiker4life sets from Ebay and hands down the mtnbiker4life is a better piece of gear.
    The TS-2TA seem like a good idea but they don't sit flush on my truing stand against the arms and as a result the hubs are always off which drives me krazy (that's right).
    I have a set of TS-2TA I will send you for free if you want to try them - I'm done with them.
    Jun 2017
    What do you mean your TS-2TA does not sit flush against the stand? Pictures?
    DOOM
    The mating of the slot in the TS-TA adapter is persnickety with respect to sitting well in the V-channels on the arms.
    The highlighted part here:
    Doesn't always like to stay put in the V here:
    This is with respect to the adapter being just right - back it out to X and then position it to Y and it is fine as far as being flush and straight in a vertical plane.
    If you aren't paying attention or are in a hurry it won't be just right and in my experience it isn't always straight and is more hassle than the benefits.
    The smaller head style on the adapter shown in the second/lower picture above is simpler to keep in place when I'm futzing around with a wheel - say working on dishing the wheel and taking it in and out of the stand a whole bunch.
    Jun 2017
    Huh, We have not had this complaint before. Most find that the TS-2TA's are faster and simpler to use than the style that you plug int the axle.
  1. Anyone using a Park Tool TS-2.2P Truing Stand
    By Burt4x4 in forum Tooltime
    Last Post: 08-24-2015, 06:11 PM
  2. Replies: 2
    Last Post: 11-15-2014, 08:27 AM
  3. Park truing stand axle adapter TS 2TA ?
    By urmb in forum Wheels and Tires
    Last Post: 01-09-2012, 05:34 PM
  4. Great price on Park Tool TS-2.2 Pro Wheel Truing Stand
    By equalme in forum Where are the Best Deals?
    Last Post: 10-13-2011, 05:42 AM
  5. Park TS-2 Truing Stand 29er Adapter
    By Quasi in forum 29er Bikes
    Last Post: 10-30-2004, 06:49 PM
Members who have read this thread: 61
