Park BBT-9 Star fitting/preload adjuster XT 760 Fix- Mtbr.com
Results 1 to 5 of 5
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    I bought a BBT-9 and it works fine exceptt for the star fitting that adjusts the preload of the non driveside crankarm of my XT 760 cranks. When i tried to loosen the preload adjuster to remove the crankarm the screw just backed out fo the star fitting.
    I finally go the crank arm off. I had to remove the star fitting assembly from the BBT-9 and tighten bolt and nut through it in order to make it work. Is there a revised version of this star fitting available from Park? because the design of the onle on my BBT-9 is junk. Thanks
    Who are the brain police?
    Reputation: Locoman's Avatar
    Try your LBS, and see if they have the separate plastic piece for tightening/loosening the preload.
    I got my saint crank before the bbt9 was available, but the two tools for installing the crank were the same ones that are used on the xtr..
    The Who - Glittering Girl
    Ween - The Grobe
    Yellowman - Strong Me Strong
    all your base are belong to us
    jrm
    jrm is offline
    So you got the shimano BB & preload tool?
    Quote Originally Posted by Locoman
    that was in the packaging of your crankset? i was wondering about those. Do you have the shimano part number for the preload adjuster? meanwhile i think im going to call park and see what they have to say..
    We have update the BBT-9. Write us at info@parktool.com for the updated part.
    Quote Originally Posted by Calvin Jones-Park Tool
    Thanks Calvin. I have the BBT-9 and emailed for the part. Received it in the mail within a couple of days.
    Dave
