OneUp EDC- Mtbr.com
Results 1 to 151 of 151
Thread: OneUp EDC
    Nov 2008
    OneUp EDC
    I installed my EDC from OneUp last night. It's pretty awesome! I also drilled a small hole above the CO2 cartridge area and tapped it to hold a Dynaplug insertion tip. In the bottom storage area, I have a Park TB-2 emergency boot and 2 zip ties.
    https://www.oneupcomponents.com/prod...dc-tool-system
    Aug 2015
    Pretty sweet! I wouldnt mind the pump version.
    Sent from my SM-G930V using Tapatalk
    Reputation: spyghost's Avatar
    Oct 2012
    OneUp EDC
    does the tool itself rust?
    what is the pointed nail like thing at the end?
    Canfield Yelli Screamy
    Keyboard Warrior SuperModerator
    Apr 2016
    One Up recently sent MTBR an EDC tool for testing. I have the tap, but didn't want to put threads in a review bike....so I'm running the pump version. So far, I couldn't be happier.
    Here's some photos.
    You can check out a full review (plus dorky video) here on MTBR.
    Nov 2008
    Quote Originally Posted by spyghost View Post
    Dynaplug tire plug.
    Oct 2012
    the only gripe here is that if you don't have the 1up pump, you'll have to carry a separate co2 dispenser as it does go in the steerer tube.
    Apr 2016
    I've heard that complaint from a number of people and I find it surprising. A C02 is pretty small. It takes up no room. Why not just duct tape one under your saddle?
    Considering how handy this tool it, I think writing it off because it lacks a C02 head is a mistake.
    Oct 2012
    please don't get me wrong - it's a great kit from 1up. the lack of the co2 cartridge is trivial and can easily be worked around, but having the option for it be included in the steerer would be great.
    Nov 2008
    I have a tube, CO2, and CO2 head on my seat with a Backcountry Research strap.
    Oct 2015
    I received mine today, the large oumo version. I'm quite impressed with it, a lot of thought went into the design to package it all in there. I have an extra quick link, small length of chain, chainring bolt, spare valve, 2 x park glueless tube patch and 1 x park tyre boot in the storage area.
    Jun 2005
    This tool is absolutey ingenious.
    https://www.youtube.com/watch?v=WLBuEfnDjFg
    Reputation: ctw55's Avatar
    Apr 2013
    OP can you re-post your photos with the Dynaplug tap?
    Debating between this and the All In multitool. The thing thats got me concerned with this is that a nasty drop may send it lose from my steertube, and the problem with the All in multi is the lack of a chain breaker.
    DECISIONS...
    Nov 2008
    Quote Originally Posted by ctw55 View Post
    Here's a direct link: https://i.imgur.com/Q3yMdBO.jpg?1
    Hopefully that works, not sure why the embed isn't working.
    Done a couple rides with mine and as an exercise worked on my bike with it. I got the 70cc pump version, 100cc out of stock. Was a little concerned with having the tool pop out of pump or pump come out of bottle cage clip. So far no problem, survived a good crash too. The retaining rings and clips are pretty tight. The tool itself is nicely designed and constructed. The allen keys are quite tight tolerance, if the fastner is rusted it has a hard time going in. The 2.5mm is pretty useless though, the 2 & 2.5mm is combined doing a Devo hat thing. I don't think any fastener with 2.5mm hole is deep enough for the tool to work. Doesn't on my grip clamps. The tire lever actually worked. If you have a really tight bead then it might be difficult, but I had no problems with my tire. Didn't try the 8mm but verified that it does fit. It'd be pretty difficult to get amount of torque required for that size, but it might work for emergency. Didn't try the chain breaker or quick link breaker yet. Did improvise jamming a bunch of the tools in to undo SHimano crank preload cap. I wish one of the spoke wrenches fit presta core, but just a little too small, I might take a file to mine as I don't foresee using the largest spoke wrench size for spoke.
    The pump is likewise nicely designed and made. It trips people out how small it is, where the tool just fits in it, but still functions as a pump with the tool still in it. Not going to get a tire up to road pressure, I tried pumping up tire I had reduced pressure for trail and it was quite difficult. I'm sure taking a flat or soft tire to rideable trail pressure would be ok. The pump and tool storage are nicely sealed with O-rings and plugs. I'm sure will keep most trail crud out. If you immerse I'm not sure though. As extra insurance against crud and for tool retension, I put inner tube condoms on it. Yes, it covers up its nice machined and anodized aluminum bits with ugliness, but for a $100 piece of kit just clipped onto bike that might not be a bad thing.
    I'm probably going to mod clip a little so I can put a removable zip tie through it for insurance too, I don't trust the thin rubber "strap" thing to do any retaining in any condition that would make it try and come out of clip.
    I imagine all the hardened stuff will eventually rust since they're steel. The bits though look like they are a bead blast finish with plating so should resist rust for a while.
    Reputation: mfa81's Avatar
    r u sure the 2 and 2.5 is combined? saw some review mentioning they have 2, 2.5, 4 and 6. on the other side 3 and 5 (8 with link tool)
    Reputation: jaydoc's Avatar
    Dec 2014
    No nasty drop will send this thing flying. It fits so tight on mine it's a struggle to pull it free with my fingers alone when seated tight.
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    Quote Originally Posted by RancidSLP View Post
    That is F#%king awesome. How did you attach it?
    Yes the 2 and 2.5 are combined, it does a step thing, but the 2mm top part is about 3mm long. Im debating trying filing down the 2mm to where can just barely use the2.5, but i dont know how well that would work.
    here's the video I saw the guy showing the different size keys, that's what got me puzzled
    https://www.youtube.com/watch?v=QX_C...t=494s?t=7m20s
    Well nuts, i stand corrected! I wasnt paying attention, there is a seperate 2.5mm. I guess they did the Devo hat thing to fit the 2mm in the space needed. So in fact, this tool has no flaws, lol!
    So my only suggestion is to make the largest spoke wrench loose tolerance so you can use as presta core remover. They made the tolerances so tight you cant. Although seperate core tool is so light its not much to carry. Also there does exist valve caps with built in removers.
    Quote Originally Posted by root View Post
    I can tell you one flaw... its green!
    recently saw that enve has one cap/valve core tool, but I can't find that anywhere to buy except the one that comes with their tubeless kit
    Richie Rude Yeti SB6C Whistler EWS 2017 - Mtbr.com
    Oct 2012
    OneUp EDC
    can the dynaplug cap/cover thread into the edc tool?
    the one on the right side that looks like a revolver...
    I doubt they are the same size in diameter. Even if it could thread in, the EDC doesn't have the shoulder to accomidate those tools protruding out. Your best bet would be to wrap those tools/plugs in tissue paper and stuff them into the OneUps tube.
    I really should pay attention. If you go to EDC's site they list Presta core tool, and after some fiddling discovered you can use the gap for the chain breaker pin as a presta core wrench. So really the only thing left that I can complain about is the storage hole for the quick link is a little loose and every time I take it apart I drop one. I can see losing it in the grass, I've lost a 4mm bit in the grass with my other tool setup.
    A small piece of black electrical tape laid over the edge of the pin hole keeps them solidly in place until you need to pull them out.
    I'm installing a Dynaplug tire plug in the CO2 spot and can still fit all my extra parts. This thing is perfect and I can't think of another thing I need.
    Quote Originally Posted by alexbn921 View Post
    did you find a good place to carry the co2 head? in case you have yours on the fork instead of pump.
    Oct 2012
    anyone ridden the steerer version out in the rain? how wet/dry were the tools inside?
    Aug 2015
    Which dynaplug will fit in the co2 spot?
    Nov 2008
    On Instagram, Dynaplug teased an attachment for the EDC.
    I plan on drilling a hole down the center of a spent CO2 and threading it to match the Dynaplug. Then I'll cut off the tip and install it at the base of the EDC. Instant solid adapter that can be removed for CO2 storage if necessary.
    I order this kit from amazon last week.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    edit don't order that kit it's labeled wrong.
    Oct 2012
    i didn't see that... link pls?
    Apr 2013
    me either!
    Nov 2008
    It was in their stories (they disappear).
    Finally got my Dyna plugs in. Spent 20 minutes making the adapter and installing it.
    OneUp EDC-20170828_184158.jpgOneUp EDC-20170828_185851.jpgOneUp EDC-20170828_190035.jpg
    Reputation: R_Pierce's Avatar
    May 2017
    I have one as well, and love it! Ive used it a few times and its well worth the price to have handy right in your steering tube.
    I dont carry a pack or any bags on the bike, so it was a no brainer!
    from yeti factory mechanic yetipolarbear instagram!
    They sent me a picture of that prototype yesterday. From a usefulness perspective, my hack is 100 times better. I used almost no room and can store all my normal items. Plus mine is lighter.
    agree using the co2 thread while being able to use oneup storage seems a much nicer solution! dynaplug seems just too big for what it does!
    Oct 2012
    Quote Originally Posted by mfa81 View Post
    i'm guessing orange is a team issue?
    they only sell green or black.
    yeah! unfortunately! maybe they will release in the future like they did with the chain guide, but apparently team issue is a thing now in the bike industry!
    I want gold! How about a me issue.
    Oct 2012
    OneUp EDC
    the bike industry 'has a lot' of issues lol
    Nice, although it seriously makes it looks like a love toy.
    Reputation: OneUp's Avatar
    Nov 2013
    Nice work,
    We might have something coming for you soon...
    Jon @ OneUp
    Quick update, had some difficulties initially using the quick link chain breaker. Turns out it matters which way the link is installed. One way it's very hard to break with the EDC, but the other it pops easy. Doesn't work with Eagle 12spd, their weird curved plate quick link doesn't fit into the EDC groove.
    Mar 2006
    Quote Originally Posted by OneUp View Post
    Nice work,
    Jon @ OneUp
    Any chance this will fit in the 70cc pump?
    Quote Originally Posted by half_man_half_scab View Post
    my dynaplug mod would. this will be close.
    Mar 2006
    Thanks for the inspirations guys, I went the cheap af route. Hacksawed the standard bacon injector and it threads right in to the EDC. Fits my 70cc pump like a glove. I was considering epoxy, but it isn't necessary. It's in there good and tight.
    Nov 2013
    Nice work!
    We appreciate a well executed hack...
    Jon @ OneUp
    Reputation: slacker607's Avatar
    May 2005
    Alright, so if I run the 70cc pump/tool combo and this hack I am 50% there. What is everyones thoughts on the specialized swat seat mounted tube/co2 carrier? Are there better options out there? My reasoning is if the plug does not fix it, I can always drop in a tube.
    Oct 2012
    Quote Originally Posted by slacker607 View Post
    i prefer mounting the tubes in the front triangle rather than behind the seat unless itís covered.
    May 2005
    What are you using to mount it?
    Oct 2012
    http://backcountryresearch.com/muthe...unt-strap.html
    Oct 2007
    OneUp EDC
    I donít like carrying stuff on my saddle for a couple of reasons.
    I donít like the way a heavy saddle feels. I can feel the extra weight when the bike is moving from one side to the other eg when going through corners or standing up to pedal. I prefer to carry any weight like this as low and central as possible, I donít notice it at all then.
    I donít like carrying tubes exposed to trail shite and uv on anything more than a temporary basis (eg a race). I know if several instances when folks have gone to use a tube and itís been fubared
    Iíve been using a SWAT box and itís been ideal. Fits lightweight tube, CO2, levers, tyre patch, spare brake pads and some duck tape. Weight is right down low so I donít notice it at all
    You can see pictures of it on my Canyon Strive here https://seekerbikes.com/2017/05/14/d...esearch-notes/
    May 2005
    Quote Originally Posted by iggs;13356619
    You can see pictures of it on my Canyon Strive here [url
    https://seekerbikes.com/2017/05/14/ditching-the-mtb-backpack-research-notes/[/url]
    Wow, awesome write up on storage options. This gives me some material to work from. I am planning an upgrade soon and was looking at the 429sl and the element. With the element I think it might fit 2 bottles, swat box, and the one up pump/tool.
ID:	1154706Click image for larger version.
ID:	1154707Click image for larger version.
    Nice!! What size tap did you use on the Co2 cartridge?
    I used a 10-24NC [#25]
    Making shit harder than it needs to be isn't awesome, it's just...harder.
    Awesome, thanks!
    Boom! Thanks again man, so easy!
    Reputation: Legbacon's Avatar
    I have had the tool and 100cc pump for a while, and wish I had bought when it was released. Something that is overlooked by people in drier climes is the way the EDC is sealed from the wet. I used to use plastic bags to keep stuff clean and dry, now it's secure except for my tube. That I strap to the saddle rails, wrapped in a nitrile glove.
    Formerly Travis Bickle
    Team Robot. "modulation is code for ďI suck at brake control.Ē Hereís a free tip: get better."
    Oct 2007
    Quick update on my EDC:
    Love it, use it loads. Fantastically handy having the tool under the top can. Even when riding with a backpack it means my multitool is right next to my hands.
    I have had one small problem. The tool started to jam getting it in and out of the top cap. Initially I thought it was dirty or the o rings had become dry. It became a big problem when it jammed in just as I needed to pack the bike into a bag for a flight which required taking the stem off. Had to lever it out with a screw driver.
    Turned out the bolts holding the tool together had started to loosen so was easy to solve once identified (used my wifeís edc). Iíve just taken the bolts out of each end and added more loctite and reset the tension on the tool. Hopefully this will prevent the problem happening again.
    Apr 2013
    Quote Originally Posted by iggs View Post
    ...use it loads...
    you have a lot of on trail issues?
  67. #67
    Oct 2007
    Quote Originally Posted by literally View Post
    Reasonable amount
    But also my fox 36 forks require an Allen key to remove the front wheel
    Also keep some trail cash in the canister on the bottom and thatís proving super useful for post ride coffee ☕️ and beer
  68. #68
    Jun 2017
    few words about* @oneupcomponents EDC Tool .
    This was a present from my wife for the new year - otherwise I would never spend so much money for a tool/pump combo even though it is very functional and has significant cool factor
    The Pump.
    Pump is 100CC but OneUp offers you smaller 70CC version . 100cc inflates* 27.5 2.35 wheel in less than 100 strokes - impressive performance. 100cc does look bulky somehow.
    The Tool.
    Tool offers you a set of Allen keys but no Philips and flat screwdrivers so you need to borrow one from your trail mate* if need to adjust your rear derailleur . Storage compartment for missing-link is loose and always gets detached when you get the tool out.
    There is an option for CO2 cartridge or storage compartment for small bits like money, patches* or a spare Presta valve core .
    The tool is well designed and has best options on the market. It can substitute many other separate tools that you'd need a backpack for. OneUp says that you are able to unlock a missing link using your EDC tool, however I could not. Chain breaker is small and looks like it will not able to brake anything besides itself however I have yet to try it when things go wild with my chain .
    #oneupcomponents #edc #tool #service #mtb #trailside #enduro #backpackfree #biketool #everydaycarry #ditchthepack #getoneup #worklessridemore
    https://www.instagram.com/p/BfOp-MyAyQ_/
    Отправлено с моего SM-J710F через Tapatalk
  69. #69
    A small piece of electric tape in the hole for the quick link secures them nicely.
    The tool also has a flat head screwdriver. The quick link separator is kind of funky, but does work on 11 speed and lower chains.
    If you need a Philips and flat won't work you could swap out the bolts to hex or carry a small bit/holder in the storage area.
  70. #70
    I tried the chain tool and it does work.
  71. #71
    Jun 2017
    Great point about changing Philips bolts to hex, electrical tape already on thanks.
  72. #72
    Jun 2017
    Quote Originally Posted by Travis Bickle View Post
    Need to try it on my old spare chains .
  73. #73
    anyone know if you thread your fork, but then one day decide to go back to a star nut instead of carrying the EDC tool (or sell your fork to someone who doesn't use EDC tool), does the star nut go back in easily (with the threads)?
  74. #74
    You can get an extra top nut to tread in or put a star nut in. It will go in just like the threads weren't there.
  75. #75
    Oct 2007
    OneUp EDC
    Quote Originally Posted by monts View Post
    Iíve just wacked in a star nut to sell a bike
  76. #76
    Oct 2007
    Finally got found to installing a tubeless repair insert tool into the bottom of my EDC
    Using a dremel I cut the threaded section of a used CO2 cartridge and butchered a cheap weldtite tool to expose the metal shaft then epoxied them together.
    I cut a tyre on Saturday and could have done with this then but at least itís ready for the next time.
    I stitched the tyre instead when I got home
  77. #77
    I guess they are making them now:
    https://www.vitalmtb.com/features/On...r-Classic,2309
  78. #78
    Oct 2007
    Yeah and if I was ordering a system I would definitely add one in. This took 20 minutes to make though and I had the parts handy anyway.
    Just made a little cover for the Ďbacon bití insert as I keep beer/coffee tokens in the canister
  79. #79
    Aug 2017
    https://www.instagram.com/p/BjnQMsDHYnF/
    https://www.oneupcomponents.com/coll...lug-pliers-kit
    mine mine MINE! They posted this up two hours ago. Nice little problem fixer to see in the production line OneUp!
    Attached Thumbnails Attached Thumbnails OneUp EDC-oneup-components-plug-plier-pro-kit-iso-966_ab7145ed-39bf-4fa7-8a75-85e8d9ff918e.jpg
  80. #80
    Oct 2007
    Quote Originally Posted by abomofo View Post
    Pliers are neat
    Used my Ďjabberí on Sunday. Gawd damn awesome, super handy and easy to use in the base of the one Up system
  81. #81
    I wish the had a mod so that the built in link pliers worked with eagle, or eagle used a regular Fing link.
  82. #82
    Aug 2015
    Anyone have both the EDC plugger and the dynaplug racer and can decisively say one is better than the other. Both are similar in price. I have no use for the link pliers and probably won't carry it but I do like that I can put two bacon strips with the EDC if I had wanted to and it's integrated in to the pump. The dynaplug is neat self contained solution.
  83. #83
    Reputation: ianick's Avatar
    Heads up, attempted to remove a set of pedals with the EDC multi-tool, it did not go as planned. The first one came off easily enough, broke the tool on the second one. We were on a bike trip to Colorado and I only brought my EDC for tools. Luckily a buddy had a Crank Bros multi-tool that was stronger.
  84. #84
    uuhhmm Yeah. This is not the best tool to remove anything with a torque over 70-80.
    Not really it's intended use though.
  85. #85
    I don't tighten pedals down that hard, mostly just snug them up. So it made sense to me that the 8mm would be able to handle it. Lightweight tool or not it shouldn't have broken so easily. Oneup took care of me and is sending a warranty replacement.
  86. #86
    방랑외국인
    Reputation: motard5's Avatar
    Would this work with the Trek Knock Block stem/headset?
  87. #87
    Reputation: Stumpy Jules's Avatar
    Apr 2005
    I also have the EDC installed in my steerer tube. It's a fantastic piece of kit and although it works very well, my only gripe is the tab on the top that you use to get the tool out. Having it on one side only makes it difficult to get out so perhaps OneUp should have put tabs on both sides to even out the load....
    2011 Lynskey R230
    2013 Yeti SB66
  88. #88
    i'm schralping yer thread
    Quote Originally Posted by Stumpy Jules View Post
    You read my mind. Another issue is that you really need to make sure the o-ring seal stays in good shape. My EDC got seriously stuck in my pump after ignoring it for a couple of weeks (still can't believe I didn't need it all that time!). Couldn't get it out on the trail, and ended up mangling the o-ring getting it out.
    That said, I love the tool and the pump. One of the best multi-tools I've owned.
  89. #89
    Apr 2005
    I have since discovered that applying a small amount of grease to the o-ring does help getting the tool out of the steerer tube. Whether that actually translates to a situation where I WILL need to get the tool out remains to be seen :-)
    2011 Lynskey R230
    2013 Yeti SB66
  90. #90
    Yup, clean the o-ring and apply tiny bit of silicone/plumbers grease. As mentioned by another poster, keep your eye on the pivot bolts loosening, hasn't happened to me, I run the pump option, but it happened to my friend who runs the steerer tube mount.
    That 8mm, I would use only in an emergency, having delt with removing pedals, even ones I installed myself that I know I didn't over torque, I know will become hard to remove and would most likely be over the capacity of the EDC. The pedals threads are done in direction to tend to be self tightening.
    The quick link separator works better in one direction, flip around if its not working.
    For bike trips I pack a separate micro ratchet and one large allen for the pedals for assembly/disassembly. WHile the EDC is good, it is way nicer to use discrete tools when you can.
  91. #91
    Oct 2018
    Anyone have issues with the 100cc pump?
    I've tested it out on a tube and I get no air. It's either pumping the smallest amount of air, or nothing at all. I feel like I can hear air coming out of the handle area when I'm pumping. If I pump it really fast, 1 out of 20 or 30 pumps will pump air into the tube, like it catches and actually pumps air. Either I'm missing something really simple, or it's broken.
    Any ideas?
  92. #92
    Oct 2015
    Quote Originally Posted by rhdins View Post
    Any ideas?
    Sounds like your pump has blown a seal. One Up are usually pretty good with warranting faults.
  93. #93
    Dec 2013
    When would one require a set of chain breaker pliers on the trail?
    Just trying to choose the stuff I need, but nothing I don't.
    Thanks.
    Sent from my SM-G892A using Tapatalk
  94. #94
    Aug 2017
    Quote Originally Posted by Suns_PSD View Post
    Thanks.
    Valid question. For me the kit sells itself with the tire plug. The quicklink tool is nice to have for the paranoid Boy Scout in me. A shoe lace can accomplish the same thing though.
    Sent from my iPhone using Tapatalk Pro
  95. #95
    Quote Originally Posted by GRPABT1 View Post
    Yup, my 100cc pumps like a champ.
  96. #96
    Dec 2013
    Your page with all the tips is really nice. However, I'm left with the realization that I still need to carry my mobile phone and car keys and therefore I'm not certain anything short of a frame bag, or a pack will ever work well for me personally.
    Thanks again.
  97. #97
    Reputation: dduk's Avatar
    They've gotta do something for those who might be interested in both the pump and the top cap. EDC tool in the pump and then something new for the top cap.... Large (long) storage canister... Storage canister plus CO2... New tool that has a small knife...
    Thoughts?
    Edit... It looks like they sell just the plastic from the tool, so you can use it as extra storage:
    https://www.oneupcomponents.com/coll...tool-frame-kit
  98. #98
    Reputation: mikeetheviking's Avatar
    Jan 2015
    Agreed! dduk!
  99. #99
    Anybody know if the EDC pump mount will fit on a carbon-framed Trek Fuel EX?
    Bike has a 68mm wide downtube which has a pretty squarish profile cross section.
    (I can't find any photos of the OneUp pump on a Trek. Have seen photos mounted to a Santa Cruz Hightower, which also has a square section downtube, but I'm not sure how big that tube is.)
    I have been given the EDC tool and steerer kit for Christmas, and on the tool's packaging the outline of the pump is shown 1:1. It measures 29mm diameter. Using that and the known spacing of standard bottle mounts (64mm) to scale a photo from the OneUp website of the pump in its mount suggests that the fit will be very close, and I can't find enough decent photos of the mount to work out exactly how the transition between the flat mounting area and the section which wraps around the pump is configured.
    Any ideas?
  100. #100
    Its going to be very close. I just measuerd mine on bike, its about 32-33mm of flat section to approx center of max mounting bolt position. There is a curve where it melds into the clamp part. If your fram is super box sectionnlike you drew, it going to be super close. You could maybe run spacers and gain a little clearance. It does fit on my Yeti SB66C which has a pretty broad flat section of downtube.
  101. #101
  102. #102
    Cheers.
    Sounds like itís worth a puntÖ
  103. #103
    Oct 2017
    What size is the tap that is used for tapping the steerer tube for this tool?
  104. #104
    Fits! Probably 1mm to spare.
    Thanks for your help.
  105. #105
    Sep 2017
    Quote Originally Posted by puffmoike View Post
    I can't find any photos of the OneUp pump on a Trek...
    I have one mounted on my Trek Stache and it fits on both water bottle holes/cages. Not sure how that relates to your Fuel though.
  106. #106
    I had to destroy mine in order to get it out. Good thing I was dealing with it in my workshop rather than in an emergency situation out on the trail.
  107. #107
    Oct 2007
    Thatís a pain, sorry to hear that
    Nipping up the bolts with some extra loctite has solved my little problem completely
  108. #108
    Dec 2013
    They really need to have 2 plastic tabs for the plugs. The one tab is a total PITA.
  109. #109
    I've found that greasing the o-rings allows for easy removal with the single tab. But yes, they should have added a second one.
  110. #110
    Reputation: travman's Avatar
    OneUp EDC w/ Dynaplug
    Based on some of the great ideas I saw on this thread I made up my own dynaplug to EDC hack. I purchased a Dynaplugģ Megapluggerô and removed the threaded portion from the plastic body. The picture of the product showed black anodized but mine came in a raw aluminum, no big deal. It came with the standard plug and the mega plug threaded sleeves as well.
    I was hoping the threads would have matched for an easy plug/play but the threads were cut on the dynaplug parts as a M8x1.0 and the OneUp is 3/8-24. So I was trying to find a way to make it work by using a threaded sleeve or something but the sizing was to close and no way to have interior and exterior threads that close in size. I also didn't want to have the plug tool sitting out to far so using a external bushing of some sort didn't work for me as i still wanted to utilize the storage tube for the extra dynaplugs and other small items.
    Ultimately I just epoxied in place but really if Dynaplug wanted to make a simple adapter to interface with the EDC they should just make these in the correct thread and done, I feel its a nice and clean install and still leaves plenty of room in the storage capsule for small items.
    Also this fits inside the 70cc pump without the storage capsule, and I do like the additional plug cap so if the plug would slide out from the sleeve at all it will be contained inside the cap.
  111. #111
    Jan 2018
    Random question I'm hoping someone on this thread can help me out with...I bought fork that has already been threaded for this tool, but I don't have one (and would prefer not to buy, at least for the time being). Is there any reason you can't go back to a normal top cap and star fangled nut once the tube has been threaded?
  112. #112
    Trying to be helpful
    Reputation: Guy.Ford's Avatar
    Quote Originally Posted by mpcremata View Post
    I know users have put a star nut back in without issue, though I question whether or not you'll be able to use the threads again later, as the startnut may damage them. Maybe someone with specific insight can chime in or you can always shoot Oneup an email [email protected].
    #THELEGENDMTB
    2016 RSD Mayor
    2018 Diamondback Release 5CA
  113. #113
    Jan 2018
    Quote Originally Posted by Guy.Ford View Post
    Thanks! Yea, I went ahead and tried it and seems to be fine. It doesn't go past the threads but the amount of torque the nut from the top cap screw is so small I can't imagine that the threading is going to cause any problems. It did take some metal shavings with it, so I doubt the threads are gonna be good for an EDC tool again, but I figured as much before I did it. Those EDCs are super cool but I already carry a tube, tool, lever, CO2, and plugs in a strap on my frame, so couldn't justify the $100.
  114. #114
    Anyone have any idea what the thread pitch is for the steerer tube tool? Really don't want to spend the. $
  115. #115
    Aug 2015
    The new edc stem doesnt require the steerer to be threaded. Its a good option.
  116. #116
    Quote Originally Posted by jacksonlui View Post
    From the pictures it looks like the stem prohibits spacers from being attached above the stem. So, if you like to tweak the position of the stem, you may be out of luck.
  117. #117
    Quote Originally Posted by dduk View Post
    Incorrect, read the detailed instructions on their site https://cdn.shopify.com/s/files/1/05...714.1550684684
    You can install spacers, although they have to be the ones that come with the stem.
    #THELEGENDMTB
    2016 RSD Mayor
  118. #118
    Ah, nice!
  119. #119
    I may have missed it, but does anyone know if the EDC stem is cnc'd or forged? I didn't see it listed anywhere. Assuming CNC'd....
  120. #120
    Has anyone tried to thread a 2019 Lyrik? I was about to do so last night and the compatibility measuring device (the other side of the star nut puller) is definitely not dropping into the stem like it has on all others that I've done. Also, by looking at the top cap, and doing a quick eyeball method over the steerer tube, it does not look like it fits. I find it hard to believe this fork would not be compatible, I have no idea what's up, and I don't really want to buy the $115 stem when i have the tap kit.
  121. #121
    Yes, I have done a few. The inside of your steerer was probably not filed smooth.
  122. #122
    Okay, thanks! I thought that could be the issue, I'll file it down more and try. Good to know it fits!
  123. #123
    collegiate race fanatic
    Quote Originally Posted by ecooke21 View Post
    I measured mine, 24 threads per inch. Looks to be 1" diameter, but most likely something custom to cut just the bare minimum of material out of a steer tube.
    I really wouldn't recommend trying to thread a steer tube without their specific tap. The whole kit works really well and makes it impossible to tap too deep into the steer tube, which could be disastrous if you remove material from the area where the stem clamps. Plus, I just looked for 1-24 taps and couldn't find anything close to the $35 OneUp charges for the tap kit.
  124. #124
    I ended up buying the tool. It should be here tomorrow.
  125. #125
    I love my OneUp EDC so much I bought another one for my commuter bike a couple weeks ago. Last weekend I tried to use the quick-link breaker function on a friend's bike, and forgot how to do it. I watched the video today and tried it with the EDC on my commuter, and discovered that they changed the design to remove the quick-link breaker function. It's no longer listed as a feature on the website, although the overview video still lists it and shows the old design.
    (original design on the left, new on the right)
    I know they have a separate set of pliers that comes with the plug add-on, but I don't know why they would eliminate that feature from the main tool, even if it's a pain in the ass to use. Maybe they needed more material to support the 8mm Allen function when combined with the 5mm.
  126. #126
    I think one of us is confused, I checked the video the extending nub is still there in your pic, the notch is missing which not sure what that was for the video doesnt show a need for it.
    I have the same design as you and I've used mine without issue.
    #THELEGENDMTB
    2016 RSD Mayor
  127. #127
    Quote Originally Posted by Legbacon View Post
    Hey did you notice any tightness when you inserted the EDC around the capsule area with the new Lyrik? I got mine threaded but the tool surely did not drop right in there like it does on previous forks I have done. It was almost unusable but after playing with some spacers I got it to fit, but it sits up higher than I would like.
    I saw that One Up says fork compatibility for the 2016+ Lyrik, "Storage capsule will fit, but CO2 cartridges may not." So I figured I would be fine, but that capsule does not go in easy either. Anyone threading a new Lyrik, you might want to be aware of this.
  128. #128
    I have had a 18 Lyrik and now a 19, the EDC tool and capsule fit with no issues. Weird.
  129. #129
    I talked with one up at sea otter and have also worked with there warranty department and they rock. Overall great group of guys and gals. Still love my EDC and was impressed with the new droppers.
  130. #130
    nope, the new one definitely can't open a quick link in the same manner as the old one. Here's a closer look at the old one:
    There's a cutout made to interface with the dogbone shape of a quick link outer plate (please excuse the crude drawing):
    The new tool design has nothing to hold the dogbone shape at the correct angle:
  131. #131
    Mar 2012
    Anyone could tell me how is the thread pitch of the EDC Tap Kit? thanks
  132. #132
    does anyone knows how close the gold topcap matches the renthal apex stem? or if the red cap is any closer in color to the lyrik boxxer red?
    Iím working on a new build and trying to figure out which color edc cap I get
  133. #133
    Nov 2018
    Hi, was anybody solving the issue with longer steering tube for EDC tube? Just wondered if there is some option to buy longer capsule (perhaps print it in 3d printer). Or different solution? Thank you for advices and sharing experiences
  134. #134
    Quote Originally Posted by Hejsa View Post
    Why is a longer steering a problem?
  135. #135
    Nov 2018
    the trouble is that the edc tool is not fixed in the steer plug. The result is noise during ride. larger storage capsule should solve it, now browsing the network if someone has the layout for 3D print of that.
  136. #136
    Stuff some foam down the steerer if you exceed the recommended length?
  137. #137
    Nov 2018
    Hi, that is the second option I was thinking about. thanks
  138. #138
    OneUp EDC
    has anybody ever attempted to re-thread the steerer tube? is that possible at all? Thinking of removing a spacer after lowering my bar but Iím not sure I can use the tap tool a second time since itís just a 7mm spacer I would remove.
  139. #139
    Nov 2013
    It's no problem to do this, it just takes some additional care. If you are at all unsure or uncomfortable please take it to your local bike shop. Always remember that you should have at least a 5mm spacer above the stem.
    - Remove the amount of steerer that you want
    - If the threads were completely cut off tap as normal
    - If some threads remain use the OneUp tap WITHOUT the guide installed and thread it into the remaining threads by HAND. You should be able to spin it in 3-5 turns by hand and this will remove any burrs from the shortening cut.
    - Next remove the tap and insert it into the guide.
    - Use the OneUp tap WITH the guide installed and thread the tap into the steerer the same 3-5 turns by HAND. This ensures that the tap is running in the same channels as the original thread.
    - Lastly install the 8mm allen into the tap cross hole and cut the remaining threads as normal.
  140. #140
    Reputation: VooDooBokor's Avatar
    Hey @oneup (or anyone else on here). Can you fit the EDC Tool + jabber plug/bacon strips (without the pliers) in the 70cc pump?
    The Enduro MTB review shows this combo, does it fit in the pump as pictured here?
    Big Honzo CR Radtail | Ripmo Squishie | RLT 9 Steel Groadie
  141. #141
    thanks for the info! In the end I decided I didn't need to be so picky with the amount of spacers I have above my headset :-) EDC has been working great!
  142. #142
    gluttons
    Oct 2007
    Anyone modified a Stans Dart to go into an EDC pump along with the tool?
  143. #143
    gluttons
    Oct 2007
    EDC pump/tool/Stans Dart
    I'll just put this here.
  144. #144
    Apr 2013
    Would love to know more!^^^^^
  145. #145
    gluttons
    Oct 2007
    Super easy. It's an EDC 100cc pump. I just sanded off most of the the knurl on the stans tool body. Left maybe 1-2mm of it in place. Then sanded down the flange on the cap of the stans tool a few mm. Took off the weed container on the EDC tool and replaced it with the modified Dart and viola. I was really lucky I sanded off the right amount. Be aware everything fits tight, there is no vibration/movement of the Stans tool because it was just the right length. This is one of the best hacks I've seen in a while. You've basically got everything you'd need for a daily rip.
  146. #146
    Sep 2018
    Quote Originally Posted by jaggittens View Post
    I don't have an EDC tool, but this is very interesting. Thanks for the idea!
  147. #147
    Reputation: SoDakSooner's Avatar
    I have both of those setups but run the edc tool in the stem. do you have them connected somehow or do they just press together in the pump? May not work in the stem, although I have a oneup pump on order so will have a matched set.
  148. #148
    gluttons
    Oct 2007
    Quote Originally Posted by SoDakSooner View Post
    Just pressed together. The cap on the Stans tool is not super hard and it has an indentation that seems to fit into the bottom of the tools plastic body. So yup friction is holding everything from knocking around.
  149. #149
    viva la v-brakes!
    Reputation: FishMan473's Avatar
    Jan 2003
    Sorry for the necro-reply, but Alex, if you're still listening, how did you thread the interior of that CO2 cartridge end to match the threads of the Dynaplug? AFAICT, the Dynaplug threads are M5 x 1-pitch, and I don't have a tap that size my kit. Is that the right size, looks like I can order one online for like $13, but would prefer a work-around.
    I have a car. I made a choice. I ride my bike.
  150. #150
  151. #151
    viva la v-brakes!
    Jan 2003
    Yep, that appears to be the correct thread, thanks! Should be easy enough to run down to my local hardware store and get the right tap 😷
  1. OneUp EDC Tool System now available
    By iggs in forum Components
    Last Post: 10-13-2017, 10:07 AM
  2. EDC bike cargo shorts/pants for CCW?
    By hhuff in forum General Discussion
    Last Post: 08-28-2016, 04:30 AM
  3. Nitecore P12Gt, perfect EDC flashlight for the helmet.
    By tigris99 in forum Lights and Night Riding
    Last Post: 05-24-2016, 08:59 AM
  4. Need your help: Carbon fiber titanium EDC LED flashlight kickstarter
    By atlasc57 in forum Lights and Night Riding
    Last Post: 10-06-2015, 02:50 AM
  5. Who here has an EDC knife, and what is it if you have one?
    By ziglaf in forum Off Camber (off topic)
    Last Post: 03-17-2012, 11:16 AM
Members who have read this thread: 177
