    Messed up my Sram X01 derailleur, any way to save it?
    Hi
    I was rebuilding my sram x01 derailleur due to creaks. After building it up the clutch spring was too weak, so I googled around and found an guide that said you were supposed to turn the clutch bolt half a turn. Apparently that guide was relevant to Type 2.0 and mine is 2.1. Unfortunately, after rotating the bolt this happened (see photo). Do you think its ok to use the derailleur like that? Can I just fill it will some silicon based sealant to stop dirt getting inside or is it a goner?
    Attached Thumbnails Attached Thumbnails Messed up my Sram X01 derailleur, any way to save it?-media-20171125.jpg
    Messed up my Sram X01 derailleur, any way to save it?-img_20171125_234141.jpg
    Evil The Following MB 2017
    Canondale Scalpel Team 2015
    Kona Raijin 2014 SS
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Looks like it is a goner. Good weekend though, everything is on sale, so good time to have to buy a new one.
    Bicycles don’t have motors or batteries.
    Ebikes are not bicycles
    Reputation: LarryFahn's Avatar
    Buy one for backup. Then run the broken one for the next 2-3 years. When it goes, you'll have a new replacement and won't have to replace your entire drive train for $4k.
    Ttyl, Fahn
    Hubbard Bike Club
    Magically Delicious
    Reputation: Cleared2land's Avatar
    I'm with Fahn on this one. Unless i'm not seeing more than meets the eye, I would continue to ride that.
    Lick yer wounds and go ride.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. Comparing stiffness of SRAM cranks - X1/X01/XX1 and Eagle X01/XX1?
    By morkys in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-18-2017, 05:37 PM
  2. SRAM X01 or X01 GXP Crank Arms - 170MM, 168 Q Factor
    By Averbuks in forum Where are the Best Deals?
    Last Post: 06-15-2016, 07:20 PM
  3. Sram x9 rear derailleur + Sram x7 shifters + shimano cassette (Shifting all messed?!?
    By Angus_fairgrieve in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-04-2015, 05:05 PM
  4. SRAM X01 11-Speed X-HORIZON™ Rear Derailleur compatible with sram 10 speed ?
    By cxboy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2015, 08:38 PM
  5. fell over, rear derailleur messed up??
    By kv2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-11-2013, 03:39 PM
