Results 1 to 17 of 17
    Hell Track
    Reputation: crewjones's Avatar
    Joytech freehub body removal
    got a 2017 Kona unit and the freewheel has a gross griding sound. I can't seem to get the freehub body off. I've only worked on Mavic freehubs in which the body just slides off. Is it possible to remove the Joytech? I know these are garbage hubs but I haven't even ridden the bike yet.
    Any help is appreciated
    Magically Delicious
    Reputation: Cleared2land's Avatar
    I'm guessing that you're using a 9mm skewer? Remove it.
    Remove the axle buy lossening the lock nut and nut on one side of the hub and,
    I'm guessing that you'll need a 10mm hex wrench to remove loosen and remove the freehub?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Reputation: LarryFahn's Avatar
    I'd say just ride it. If there's an issue, it'll probably be taken care of under warranty.
    If you have to remove the freehub, you'll have to have a very stable workbench and vice. Put the 10mm in the vice and the wheel on top of the wrench. Turn the wheel ccw. It will be on there VERY tight.
    Hubbard Bike Club
    Hell Track
    Yes, 9mm QR. No warranty most likely, I bought it used. I'm going to take it apart again this weekend and give another crack at it. If I can't figure it out I'll just ride it like you said Larry and see what happens.
    Hell Track
    It takes an 11mm hex. No bike shops have one. I've been to hardware stores and auto stores. Looks like there are some on the web for sale. Why the heck would they use such an uncommon size?
    Wtf?
    Hubbard Bike Club
    Hell Track
    I'm currently looking for a rear wheel replacement in 27.5+. I ordered the right size wrench but it probably wont even be worth my time to try and fix this POS
    Magically Delicious
    Correct. The possibility of fixing this might be moot, but I would at least make an effort to find and correct the problem.
    Have you ever serviced this freehub?
    Hell Track
    No, It's fairly new. Bought the bike used. I can't find much out there for a replacement wheel that's not super expensive. I'm gonna do my best to fix it though
    Hell Track
    No dice. I used a 7/16 allen and literally stood on top of it and the freehub would not budge. What a POS. New wheel time I suppose, but It's not easy finding a 27.5+ without a boost hub at a decent price
    Put the hex wrench in a vice and turn the wheel. Or a big piece of pipe on the wrench.
    Magically Delicious
    It will take some effort, but it will come loose.
    If new wheels are too expensive for you and you're not able to service it back to life, then a replacement freehub can be acquired for a reasonable price.
    If you go the replacement route, anti-seize the freehub bolt threads and torque correctly.
    Reputation: tk1971's Avatar
    My 2016 Unitís Joytech hub started slipping under load. Being a singlespeed I almost lost my nuts when that happened.
    I got the correct 11mm and a 5 ft breaker bar. Still no go. Did some Googling and read that some Joytech freehubs are welded.
    Good news is that a DT Swiss 350 fits right in. I even re-used most of the spokes and nipples... most.
    Good luck.
    Feb 2019
    Do you put the 11mm into the hub from the outside or the inside? Thanks in advance.
    Feb 2019
    Remember it is very likely reverse threaded.
    Magically Delicious
    It's not reverse threaded.
    Feb 2019
    Did you ever get that free hub to come loose?
  1. Gravity Hub - Freehub Body removal?
    By sockeyehaines in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 3 Weeks Ago, 12:20 PM
  2. Mavic Cross Link freehub body removal?
    By djpubba in forum Wheels and Tires
    Last Post: 07-21-2017, 06:25 PM
  3. Kona Unit Joytech freehub body
    By tk1971 in forum Wheels and Tires
    Last Post: 10-29-2016, 03:51 PM
  4. How do i service this pivit/joytech? ss hub?
    By opnykanen in forum Singlespeed
    Last Post: 09-28-2015, 05:18 AM
  5. Replacing rear hub bearings (joytech)
    By arisaast in forum Beginner's Corner
    Last Post: 06-27-2013, 01:58 AM
Members who have read this thread: 25
