Hub Axle problem, why is this turning?- Mtbr.com
    Reputation: Toogy's Avatar
    May 2015
    Check out this picture, why is this turning when I try and remove the rear thru axle on my 2018 Giant Reign? I have to secure the spot where the arrow is pointing to remove the axle.
    I don't notice anything else weird about the hub, this just started happening the last time I tried to take the wheel off.
    Attached Thumbnails Attached Thumbnails Hub Axle problem, why is this turning?-img_5619-2.jpg
    My MTB adventures! Subscribe & Like!
    http://toogyhowsermtb.com
    Reputation: Black Dog Suspension's Avatar
    Dec 2017
    With the wheel out, make sure the silver locknut is tight. These hubs are re-branded all over the place and are notorious for coming loose. If that's not it, check that your axle isn't bent or there's a burr somewhere where the axle is hanging up
    Cheers
    Reputation: J.B. Weld's Avatar
    The locknut needs to be tight against the cone, you need 2 cone wrenches to lock them together.
    I brake for stinkbugs
    May 2015
    Thanks guys, that was it! fixed up now
  1. Replies: 2
    Last Post: 09-21-2017, 12:56 PM
  2. Hub axle WANTED!! Reynolds hub rear axle!!
    By sccott in forum Wheels and Tires
    Last Post: 09-24-2013, 12:19 PM
  3. Replies: 34
    Last Post: 03-17-2012, 10:05 AM
  4. Replies: 0
    Last Post: 04-05-2006, 09:52 PM
  5. Problem, Problem, Problem?
    By Mack in forum Shocks and Suspension
    Last Post: 07-13-2004, 08:41 PM
Members who have read this thread: 52
