Home compressor for pumping tires and air blow gun usage?- Mtbr.com
Results 1 to 24 of 24
    Apr 2019
    I am looking to purchase a small compressor at home that would be used for setting up my tubeless tires and additionally use it with a air blow gun to 'dry clean' my bike after the wash.
    Does any one have any recommendations on what would be appropriate? Something oil-less and powered by electricity is a requisite.
    Any compressor with a tank will work. Even a tiny 1 gallon will seat tubeless tires.
    I have a pancake ingersol, but it's obnoxious loud. I would look at a quiet model.
    Reputation: J.B. Weld's Avatar
    Yep^ and a blow gun is also the best tool to seat tires imo.
    I brake for stinkbugs
    Oct 2018
    Harbor Freight compressor is affordable and will do as you've asked.
    I do not know if they sell oilless ones (Haven't checked). Also, some of their models have cast rings, not nylon (maybe all of them do?).
    Reputation: upstateSC-rider's Avatar
    I was able to find a 1 gal tank (I think) pancake compressor at home depot for $45 on clearance last year, be patient.
    Niner Jet 9 RDO, Scalpel 29, XTC 650b, 04 Stumpjumper FSR Pro, Trek Rigid SS - No suspension, no gears....no problem
    Reputation: fredcook's Avatar
    +1 for the Harbor Freight compressors... at least the mid sized w/oil models. Specifically, their 2.5 HP 21 gallon model. I didn't expect a whole lot from it at that price point, but it has been going strong for years now. Might be more than you need, but I use it to run all my pneumatic tools including ratchets, nailers, saws, impacts, etc. Haven't painted with it... not my thing. The only thing I did was add a moisture filter.
    Like I said, probably more than you need, but once you get a whiff of using pneumatic tools, you'll never go back (and you'll need a larger compressor).
    You didn't quit riding because you're old, you're old because you quit riding.
    Oct 2018
    When I was shopping a number of years ago I was surprised the SCFM of the Harbor Freight Models (Central Pheumatic?) was higher than some retailers such as Craftsman.
    Jan 2009
    Yea, a modest harbor freight compressor is good enough. I'd also look into these two bits.
    digital tire inflator with gauge
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    presta adapter for above gauge
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ I got a similar digital inflator that had a schrader chuck crimped onto the hose. I cut it off and put a presta/schrader air chuck on it like you'd find on a bike floor pump.
    I prefer an inflator with a bleed valve as inflation is rather coarse and the gauge doesn't correctly read tire pressure until you stop the air flow. I find it to be easier/faster to over shoot than bleed down.
    Do the math.
    Reputation: Mr Pig's Avatar
    Why do you want an oilless one? Even a compressor that will stand up to light industrial use is cheap but once you start including words like 'oilless' and 'quiet' into the description, not so much. Remember that if you get one with a decent sized tank you don't need to run it all the time. Fill the tank, switch it off and there will be enough air in store to get your jobs done.
    Apr 2019
    What’s a good adapter for presta with air disconnects? I have a standard stand up compressor for my garage. I also have a new bike with tubeless wheels.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by Mr Pig View Post
    I'll second this. Oil-less compressors generally suck and are significantly louder than their oiled counterparts. If all you're doing is seating tires you can get 10 years out of the original oil so it's not like they are a maintenance nightmare.
    I've got an 80 gallon 6hp oiled compressor at the shop that makes less noise than the 30 gallon 3hp oil-less compressor at home.
    Dec 2013
    Nowadays my small cheap noisy oil-less type is OK for my application, mainly topping off car/moto/trailer tires and occasionally blowing something off... I never really use it for bike tires except if needing the flow rate for getting loose tubeless bike tires to catch air. Years ago I had a nice big oily one when I used air tools needing the high CFM (and an in-line oiler). Oil-less might be preferred for painting and other applications where oil might be bad.
    I have the typical quick connect on the hose and if needing to seat loose tubeless tires I'll put the rubber tipped air blow gun on it and shoot air directly into the valve stem (with core removed). This yields a higher flow than going through the gauge or other air chucks I have. The old Silca type chuck can work well too, but they're a bitch to get off the stem when pressurized.
    Do the math.
    Dec 2017
    Quote Originally Posted by hans2911 View Post
    Oil free compressors are AWFUL. Get yourself one that uses oil.
    Quote Originally Posted by twodownzero View Post
    Oil compressors have some advantages but if you're just using it to inflate bike tires or occasional light use a cheap oil-free one will still probably last a lifetime.
    I bought one of the $100 cheap compressor from HD about 4 years ago and it started falling apart on me. Several of the valves started leaking and was not repairable.
    So, I am trying this one...6 months later and I like it. I use it for other things too.
    https://www.makitatools.com/products/details/MAC700
    Cheers,
    Mike
    Jun 2015
    I've had this little one for about a year now:
    https://www.homedepot.com/p/Californ...060S/300500747
    It's been great for bike stuff.
    Apr 2005
    How do you hook up the compressor to bike valve?
    Sent from my SM-G965W using Tapatalk
    Quote Originally Posted by Picard View Post
    If you mean to a presta valve, I use these.
    Name:  presta adapter.JPG
    Dec 2017
    Quote Originally Posted by J.B. Weld View Post
    I don't disagree, but even occasional use would drive me nuts. The oil free ones just make electricity into noise, it seems.
    Dec 2013
    I mentioned earlier that I got a digital inflator off amazon. So...I went to check the pressure in my moto tires and they read 10 psi low. I corrected the pressure and rode. Later I got to wondering so checked the pressure with my old mechanical gauges, a pencil type about 25 years old and dial type I got when I got my first car back in '72. They both read 10 psi over what I had set with the digital inflator, agreeing to within 1 psi, as they always have. I haven't checked the battery or investigated further.
    I use a Meiser Accugage on my mtb tires.
    Do the math.
    Quote Originally Posted by Lone Rager View Post
    I've never been comfortable with digital tire gauges. Only because, like you, when I compared them to mechanical gauges that read the same, as well as the output gauge on my compressor, digital gauges are always off. But admittedly, I've never spent the cash for a "high end" digital gauge, whatever that may be.
    Speaking of compressor output gauges. I've been in the lazy habit of just setting the output to the pressure I want in my tires. I stick the hose on the tire, and let it air up until I don't hear anymore air going through. I seldom go back to check the tire's pressure after that. I've learned over time that it's within a needle width of what I was after, so I just don't bother. Anyone else that lazy?
    use a leaf blower to dry the bike
    Apr 2005
    Quote Originally Posted by Humpy View Post
    I will check it out at home depot canada
  1. Replies: 7
    Last Post: 06-19-2013, 12:50 AM
  2. Replies: 17
    Last Post: 06-07-2007, 12:39 PM
  3. "Don't blow SSer!! don't blow!" teva race report (xpost)
    By brg in forum XC Racing and Training
    Last Post: 06-05-2007, 12:43 PM
  4. Replies: 8
    Last Post: 06-04-2007, 06:53 PM
  5. Blow by Blow,, how to miss first place by 44 seconds.
    By zon in forum California - Norcal
    Last Post: 02-28-2007, 08:15 PM
Members who have read this thread: 135
