Results 1 to 25 of 25
    dmo
    dmo is offline
    Reputation: dmo's Avatar
    Grease for HS cups on carbon frame?
    I'm installing a headset for the first time on my carbon frame. Do I grease the cups or not? I'm using the park professional HS press. Any other tips for doing this? Upper cup first and then lower?
    Sent from my SM-G955U using Tapatalk
    Aug 2015
    You'll get a variety of answers. Bone dry, grease, antisieze, and carbon paste. Any will work but i prefer to use grease because it makes sense. Helps ease it in, remove it in the future, prevents water from getting in, and may help avoid creaking. More importantly, I'd make sure the crown race is on all the way and the cups are in parallel to each other. Ive been using Park PPL without issues. Seems to work for most things. You can go as far as freezing your cups so they shrink and drop it in but grease seems logical, imo.
    Sent from my SM-G930V using Tapatalk
    dmo
    dmo is offline
    Freezing? Really, people do that?
    I'm assuming a thin layer of any high quality grease is good?
    Mudhorse
    Reputation: Grassington's Avatar
    Jun 2017
    ^ Aye, freezing will help, and it's much better than trying to heat up a carbon frame. I worked for a company that made massive turbos a while back, and there was a crucial part that was an interference fit. They kept them in an old domestic chest freezer until it was time to fit them, and once it was on there and acclimatised it was good for the horrendously harsh life ahead of it.
    I'd err on the side of caution and use carbon fibre assembly paste. There's a school of thought that believes some greases can degrade CF resin, and another school of thought that says nah, any grease is fine. CF paste should by rights be OK, and I doubt the gritty bits will cause issues, prolly just get squished out of the way.
    Hose me down till the water runs clear.
    Jul 2015
    Good ole normal park tool grease, works for everything
    Sent from my XT1585 using Tapatalk
    Aug 2015
    Spit works too
    Mudhorse
    Jun 2017
    This has got me thinking now. Maybe CF assembly paste isn't so good because of the grit - the cup might go in OK, but could be a mare to get off again. Dry, water or soap could be troublesome because of galvanic corrosion. Has to be a non-gritty CF-friendly grease then. Park claim their PolyLube 1000 grease is CF-safe, and I'm sure other alternatives are available.
    dmo
    dmo is offline
    I just checked with the frame manufacturer (spot) and they said C.F. assembly paste
    They've never heard of freezing though...
    Rocks belong
    Quote Originally Posted by wytemike21 View Post
    this
    I like 'em long, low, slack and playful
    Reputation: Black Dog Suspension's Avatar
    Dec 2017
    I wouldn't use carbon paste. The grit can act as an abrasive against the carbon as the cup is installed & removed. It's a tight fight so there is no need to add more holding power. I've seen carbon frames destroyed from BB cups moving and "sanding" the carbon away. Most bicycle specific greases should be just fine.
    Turns right to go left
    Reputation: 410sprint's Avatar
    Oct 2012
    When installing headsets and PF BB's on carbon frames, I have have used a light coat of teflon paste (Lowes plumbing department).
    Reputation: scoobiemario's Avatar
    Aug 2016
    I'm glad I've found this thread.
    I have similar question. I removed/reinstalled shock bolt on my Jeffsy. Used light coat of grease on it. It will contact frame here and there.
    Does anyone know if Finis Line Ceramic Greas is carbon safe?
    Can't find that info anywhere.
    Jul 2015
    I don't see any issue with it is has a neutral pH and is non-corrosive...people use quite a few diff greases on pivots..I use marine grease and it works great
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Neutral pH? What does this have to do with it? Where does this specification come from?
    What grease is corrosive?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Aug 2016
    I just got reply from FinishLine support:
    Finish line ceramic grease: "It is safe. As is our Premium Teflon Grease" to use where it can contact carbon fiber parts.
    Reputation: LarryFahn's Avatar
    This is a trick question. First, I agree with everyone about not using carbon paste cause of the abrasiveness.
    I contacted my frame manufacturer, Trek and Specialized.
    I received 3 different answers. I asked about the seatpost, the headset/bb, and if grease or paste should be used or causes damage. Each reply was different to my surprise. I've used grease and haven't seen any damage. Ttyl, Fahn
    Hubbard Bike Club
    Magically Delicious
    Santa Cruz clearly states on their website to apply grease to all pressed headset cups
    Mudhorse
    Jun 2017
    Tacx T4765 carbon assembly paste should be fine - it uses tiny plastic beads instead of abrasive grit so it doesn't grind like other CF pastes.
    Sep 2014
    Sorry to revive an old thread. My pressfit BB is also creaking, I installed the plastic cups into my carbon frame without any grease. I have Bel-ray waterproof bearing grease (aluminum complex). Can it truly damage the carbon fiber? It seems very far reached. Thanks for helping me out!
    Well, carbon is technically plastic, so its possible some compounds might cause reactions in the resin. On my carbon bike, the press fittings are into aluminum shells so I use anti-seize. grease/oil can get acidic, one of the reasons you change your oil in your engine, but I don't think that's the main worry with carbon, although it won't be good if it promotes corrosion with metal parts. It's more possibility of petroleum messing with the binder/resin, I think.
    I only use carbon paste where there is a clamping friction fit with direct carbon, the seatpost and handlebars.
    Magically Delicious
    You will be just fine using grease to lube outer races for pressing bearings.
    Grease has ongoing and frequent contact with carbon fiber in aerospace applications. I don't know of any published warnings to avoid such contact in these applications.
    I'm not overly worried about it, I use antisieze that I use for car parts. But if you're really worried I'd defer to asking the manufacturer. Most of the carbon were talking about is from China, not aerospace grade stuff.
    Reputation: J.B. Weld's Avatar
    My (carbon) frame manufacture recommended grease for PF bb and so did Wheels Manufacturing.
    I brake for stinkbugs
    Sep 2014
    Thanks very much for your replies.
    I also imagined normal wear & tear to have a greater impact on the carbon's longevity than any grease could!
    Reputation: the_joe's Avatar
    Feb 2017
    Grease having adverse effects on carbon/resin is an old myth that will never die. Assembly paste should never be used on press fit parts because there is no use for additional friction. Just use grease
    2008 BMC Fourstroke 19-559 ISO (RIP in peace)
    2017 BMC Speedfox 25-622 ISO
    2017 Salsa Timberjack 40-584 ISO
  1. Replies: 27
    Last Post: 01-07-2017, 04:10 PM
  2. To grease or not to grease... carbon Niners.
    By h2otaco in forum Niner Bikes
    Last Post: 08-12-2014, 04:30 AM
  3. Do you grease your headset cups???
    By CragRat in forum Turner
    Last Post: 12-11-2013, 05:17 PM
  4. Grease gun and grease recommendation
    By wonny in forum Intense
    Last Post: 10-17-2012, 11:35 PM
  5. To grease or not to grease......
    By OutThere in forum Bike and Frame discussion
    Last Post: 04-25-2012, 01:39 AM
Members who have read this thread: 89
