Cutting fork steerer tube- Mtbr.com
Results 1 to 6 of 6
    meow
    Reputation: Cato's Avatar
    I'm about ready to install a new fork and am not sure that I should invest in Park's saw guide to cut the tube. Has anyone used other alternatves, and with what results?
    Reputation: Lotusfinger's Avatar
    Quote Originally Posted by Cato
    I use a tubing cutter, available at any hardware store. Some people don't like to use them cause they work by displacement and can slightly flair the tube. But if you take your time and tighten in small increments this won't be a problem.
    And remebmer, you can always cut more off later but you can't add back on.
    Lotusfinger
    I have used
    an old stem. Just clamp it on a hair below where you want to cut. If you'r e off a little just use a file to even it out.
    A wheelist
    Reputation: Mike T.'s Avatar
    Use an automotive hoseclamp as a guide and hacksaw it. File smooth and chanfer edges.
    Reputation: frank n. beans's Avatar
    I have used the following methods with success: Piece of tape, pipe cutter, an old stem, Park saw guide.
    Pipe cutter took a while, I'd rather use a hack saw.
    As long as you are careful, work slow, and can stay on course, a piece of tape as a guide works just fine.
    The old stem trick, personally I thought it was easier just using a piece of tape.
    Using the Park guide makes the task simple, fast, accurate, and brainless.
    How many forks do you plan on cutting in your lifetime? The guide is $25. All things considered, it is worth it to me.
    meow
    Thanks for the feedback. It's worth $25 for the saw guide to get it right the first time. Measure twice and cut once!
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. steerer tube vs stem vs bar wt
    By drc in forum Weight Weenies
    Last Post: 07-23-2004, 08:03 PM
  3. Replies: 5
    Last Post: 04-14-2004, 08:19 AM
  4. cutting steerer tube
    By BikeIsBetterThanMe in forum Tooltime
    Last Post: 03-26-2004, 06:31 AM
  5. cut fork tube
    By mihurka in forum Shocks and Suspension
    Last Post: 01-16-2004, 09:54 PM
