Results 1 to 10 of 10
    Reputation: Nuno Machuqueiro's Avatar
    May 2016
    cheap bearing removal tool
    Any advice on where can i find a good and cheap bearing removal tool
    like the superstarcomponents type https://www.superstarcomponents.com/...tting-tool.htm
    6802 and 6900 bearings - lapierre spicy
    Reputation: Mr Pig's Avatar
    Do you have any experience of removing and fitting bearings?
    Feb 2010
    You can get this tool from eBay. Search YS-BT1112
    May 2016
    my nomad mk1 made me an almost professional
    never changed on lapierre
    May 2016
    thanks arnea
    unfortunately out of stock 6802 size
    If I understand the tool correctly, a socket or piece of plastic pipe larger than the bearing and a socket the same size as the bearing and a piece of threaded rod, some nuts and washers would do the same thing.
    Plays with tools
    Reputation: customfab's Avatar
    A square end punch and a hammer can do wonders in competent hands. Purpose built tools make life a lot easier and are a must for professional shops but if you need to hack it you might already have the tools.
    May 2016
    im trying to avoid hammer because this time want to change bearings without disassemble rear triangle
    i'm already armed with a threaded rod nuts and washers
    thanks for the replays
    happy new year with a lot on fun on the trails
    Quote Originally Posted by Nuno Machuqueiro View Post
    Curious, why do you want to replace the bearings in situ? If you are going to replace them all, anyway, wouldn't it be easier to work with the triangle separate from the frame?
    May 2016
    Yes you right but have 2 cable holder with stuck bolts
    It's easy and very straightforward to access the bearings. Even without removing the triangle.
  1. Motion Pro vs Real World Cycling Pivot Bearing Removal Tool
    By oberwil in forum Shocks and Suspension
    Last Post: 08-07-2017, 09:31 PM
  2. Replies: 0
    Last Post: 08-07-2017, 09:14 PM
  3. Tallboy bearing removal tool
    By EJ_92606 in forum Santa Cruz
    Last Post: 05-20-2013, 07:07 AM
  4. Point One Podium's Bearing Removal Tool...
    By Drdan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-15-2012, 12:24 PM
  5. Giant Tool Shed Multi-Tool - Ten Bucks - incl. chain tool
    By aa240sx in forum Where are the Best Deals?
    Last Post: 06-23-2011, 11:17 AM
