Chain skips on large cog- Mtbr.com
Results 1 to 3 of 3
    I just put a new chain on my bike (the other was stretched) and am having troubles with the chain skipping when I ride on the small cog in the back. Initially I figured the chain needed to wear into the teeth on the big cog, and it has gotten better, but I still have a problem when climbing steep grades. Could it simply be that I should remove a link from the chain? Is there too much play?
    This came to me after I had the chain jump off the small chainring while climbing stairs the other day. Can ahyone help?
    Kula
    Reputation: MootsRider's Avatar
    If the new chain is skipping up climbs (and when you crank hard on the pedals) you may need to replace the cassette too.
    Get your freak on!
    Quote Originally Posted by MootsRider
    Had the same problem here. I say time for a new cassette.
  1. Chain skipping on middle ring of NRS
    By BobbyWilliams in forum Giant
    Last Post: 09-23-2007, 03:35 PM
  2. What do you use to lock up your bike?
    By LavaPunk in forum General Discussion
    Last Post: 02-06-2005, 01:20 AM
  3. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  4. Replies: 9
    Last Post: 07-13-2004, 04:37 PM
  5. Backpedaling issues
    By GMeister in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-27-2004, 10:34 AM
