Results 1 to 9 of 9
Thread: Carbon glue?
    Jul 2018
    Carbon glue?
    Hi,
    One of cable guide well nuts has detached from the frame of my RFX (carbon).
    What type of glue can I use to fix it back in?
    Will this do a good job
    https://www.amazon.co.uk/Gorilla-614...lla+epoxy+25ml
    Sep 2018
    Quote Originally Posted by wpuk@ View Post
    Hi,
    Subscribed. A friend had a similar thing happen with his Turner Czar.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Call Dave Turner and get the info directly from the owner of the company
    Reputation: supersedona's Avatar
    Dec 2012
    Short of the factory warranty information line(best option). I would recommend an epoxy specifically designed for carbon/composite work. There are some unique properties and incompatibilities that would give me reluctance to using a generic glue(such as attacking the surface gelcoats or epoxies.
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
    Jul 2018
    Quote Originally Posted by supersedona View Post
    Cheers, glad I didn't go ahead.
    Quote Originally Posted by mtnbiker4life View Post
    Will do.
    Was hoping to get it sorted today.
    I'll post the info here when they get back to me.
    Jul 2018
    Got an email from DT.
    This is exactly the stuff he has recommended, they do different versions. (he provided an image which I cannot upload on this forum)
    https://www.amazon.co.uk/gp/aw/d/B0006O1ICE
    Also advice on maintainence from DT
    Periodically remove all the cable guide screws and grease the threads then lightly snug. This will make them easier to adjust / remove in future so less stress on the insert.
    .Name:  JD weld.png
    Edit: back on PC, can upload image DT sent
    Plays with tools
    Reputation: customfab's Avatar
    3M scotchweld DP420 is a product that more than a couple frame manufactures use to bond the frame together, it will work fine for cable stops as well. It's not cheap though.
    Reputation: LyNx's Avatar
    That JB weld seems to be popular in the US, but down here, I stuck to pretty much the most trusted name in that area and used West System plastic repair kit to stick back guides onto carbon frames and it worked excellent. Not cheap, but well worth it, still have aload left, works on so many things, $$ well spent.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    I've used JB Weld on a carbon frame and it stuck extremely well.
  1. Glue for carbon fiber to aluminum
    By nekkrush in forum Frame Building
    Last Post: 07-16-2015, 07:35 AM
  2. Replies: 3
    Last Post: 09-12-2014, 01:23 PM
  3. Gluing carbon. What glue do you prefer?
    By pvd in forum Frame Building
    Last Post: 06-04-2012, 04:27 PM
  4. Grip glue for slipping seat post on carbon frame?
    By Will Goes Boing in forum General Discussion
    Last Post: 11-11-2011, 10:33 AM
  5. Patch-kit glue - Can you get just the glue?
    By Surestick Malone in forum General Discussion
    Last Post: 06-04-2006, 07:48 PM
Members who have read this thread: 58
© Copyright 2018 VerticalScope Inc. All rights reserved.
