broken side bolt on a thomson x4. how to remove any tips?- Mtbr.com
Results 1 to 10 of 10
    Reputation: Lordie's Avatar
    broken side bolt on a thomson x4. how to remove any tips?-11235802_10153101155299624_7002884008758278636_n.jpg
    broken side bolt on a thomson x4. how to remove any tips?-11760233_10153101155339624_394609950190161788_n.jpgbroken side bolt on a thomson x4. how to remove any tips?-2015-08-04-15.45.54.jpg
    i was thinking of purchasing an easy out and try it.
    Quote Originally Posted by Lordie View Post
    ...i was thinking of purchasing an easy out and try it.
    And/or a left handed drill bit.
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    You're gonna have to drill that out. Be careful!
    Todd :thumbsup:
    Reputation: J.B. Weld's Avatar
    It should come out pretty easy since there's no tension on it, I'd just try a small regular drill bit if you don't already have a screw extractor (easy out).
    Reputation: watts888's Avatar
    Oct 2012
    screw extractor. make sure you use a small drill bit to dimple and provide an angled surface on the center of the bolt first so the extractor has surface to grab to. Never know, since there's no tension on it, just using a small drill bit might be enough to screw it out on it's own (push it through instead of backing it out)
    Assuming that the bolt can be screwed right through, a regular drill bit from the broken side will likely wind the bolt out.
    thanks all will try with just a very small drill bit and than see how it goes b4 i get the easy out
    manage to drill it out and its all good now. thanks all! appreciate all the help. u guys rocks!
    Go to home depot or any hardware store and buy a quality set of drill bits, an ez oit kit aND center punch. Cobalt bits preferred.
    Use the center puch to create the dimple, then drill a hole using the smallest bit you have and work your way up to the recommended size for the size ez out/screw extractor you plan to use.
    Don't skimp on the drill bits because a cheap one will break as you're about an 1/8" in and then you're royally screwed
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    Late to the OP problem but here's a much simpler trick to try first, before you break out the tools. Put the free part (the one with bolt head) back in the hole, find the angle it used to be in when it snapped, and try unscrewing it carefully, while maintaining axial pressure on the bolt head. Not guaranteed to work but it's worth a quick try.
    26" rigid SS 4130 BB7 nylon-flats ESI latex-tubes non-lubricated-8spd
  1. Any Tips on Removing a Broken Compression bolt?
    By Shakester in forum Brake Time
    Last Post: 08-08-2014, 08:45 AM
  2. Replies: 9
    Last Post: 05-22-2014, 07:28 PM
  3. Rockshox Revelation - broken shaft bolt (left side)
    By sp00n82 in forum Shocks and Suspension
    Last Post: 05-22-2014, 03:43 PM
  4. Does it matter which side BB cup you remove first when removing a BB?
    By Tsetse in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-27-2013, 08:20 AM
  5. Sleeping with a broken collarbone and 2 broken ribs (on the same side)
    By chainsawgeoff in forum Rider Down, injuries and recovery
    Last Post: 04-23-2012, 07:34 PM
