BMX Bottom Bracket- Mtbr.com
    Reputation: Fredmertz51's Avatar
    BMX Bottom Bracket
    Where can I find detailed instructions on installing a "press-in bottom bracket" crankset?
    Reputation: logbiter's Avatar
    park tool site should get you going.
    http://www.parktool.com/repair_help/ashtabula.shtml
    It's been over 20 yrs since I've done anything with a BMX bike, and i was too young to know anything then (=
    Quote Originally Posted by Fredmertz51
    BMX Bottom Bracket
    Actually, I have the 3-piece . How do I remove the old crank, and what do I need to know to install a new one?
    check out the
    other BB guides there on the repair help section of the park site. http://www.parktool.com/repair_help/...ttom%20bracket
    With a 3 piece crank, you'll first need to remove the crankarms. I guess most bmx cranks use a pinch bolt to hold 'em on, or if like most road/mtn bikes a bolt hold's em on the BB spindle. You'll likely need the proper tool to pull the arms off, same with removing/installing the BB cups.
  1. How to grease a bottom bracket?
    By Dave. in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-19-2004, 09:40 PM
  2. bottom bracket type??
    By Styles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2004, 10:06 AM
  3. @#$%^&* Shimano bottom bracket mounted derailler
    By old_dude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2004, 10:04 AM
  4. brand new bottom bracket, broken?
    By kenaran in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2004, 10:47 AM
  5. Help with bottom bracket
    By DoothaBartman in forum General Discussion
    Last Post: 04-10-2004, 02:44 PM
