Bearing Extraction on Non-Flat Surface?- Mtbr.com
Results 1 to 9 of 9
    Reputation: OttaCee's Avatar
    Jul 2013
    Attempting to replace my rear triangle bearings on my Niner Jet 9 RDO.
    Noticed that the surface to place my bearing removal tool (RWC Guide 11) is not flat. Making it almost impossible to get the tool and rod lined up straight.
    Is there any tools that remove bearings that can deal with non-flat surfaces?
    Trail Ninja
    Reputation: Varaxis's Avatar
    Blind hole bearing puller. It pretty much wrecks the bearing due to brinelling though. Can be concerning to use without something securing the workpiece you're extracting the bearing from too.
    Your extractor is intended to be gentler, so the bearing can be reusable.
    "The challenge is not in developing new ideas, but in escaping old ideas."
    Jul 2013
    Quote Originally Posted by TraxFactory View Post
    got a pic?
    Ride More - Suffer Less
    Reputation: TraxFactory's Avatar
    Sep 1999
    Quote Originally Posted by OttaCee View Post
    Using a socket, cant you just tap that thing?
    Maybe some wooden shims putting some light pressure on it so see if the bearing comes out easy..
    Jul 2013
    Ended up returning the RWC handle set and getting this Ibis one that includes feet to extract on uneven surfaces
    Ripley, bearing, Clemens, tool
    Kind of wish RWC or another company would develop a similar product since I dont need this entire Ibis kit.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by Varaxis View Post
    If you're not going to replace a cartridge bearing, don't remove it. End of story.
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ totally, as removing often damages it. Pulling or pushing on the unsupported race, usually in the inner, either installing or removing a bearing very often damages it.
    What, me worry?
  1. Pivot bearing extraction query
    By FullSusRuss in forum Tooltime
    Last Post: 2 Weeks Ago, 04:54 AM
  2. Broken Brake Caliper Bolt Extraction
    By SingleSpeedSteven in forum Tooltime
    Last Post: 03-25-2018, 10:09 AM
  3. Blind hole bearing puller: damage to bearings on extraction?
    By watermonkey in forum Wheels and Tires
    Last Post: 08-12-2017, 05:43 AM
  4. Replies: 22
    Last Post: 12-14-2012, 11:06 AM
  5. XC Pro pedal bearing extraction
    By hairstream in forum Vintage, Retro, Classic
    Last Post: 06-09-2008, 08:58 AM
Members who have read this thread: 49
