    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    Advice on using clear coat on decals for matte carbon frame
    I put some gloss black decals on a matte carbon frame (generic Chinese, no branding). If I use a matte clearcoat to help durability of the decal, will I need to do the whole frame? And will it look terrible with just the section around the decal clear coated?
    Is there another option, like maybe using a small brush to paint the edge of the decal?
    This forum says "DIY Projects" so hopefully this is the right place for this.
    Reputation: upstateSC-rider's Avatar
    I'd say try an inconspicuous spot like under the BB or chainstay first to see how it turns out, chances are the level of matte-ness (is that a word?) will be different. I think best results would come from matte clearing the decal with some painter's tape around the decal so only the decal is affected. Good luck and post a pic when you're done.
    Niner Jet 9 RDO, Scalpel 29, XTC 650b, 04 Stumpjumper FSR Pro, Trek Rigid SS - No suspension, no gears....no problem
    Magically Delicious
    Reputation: Cleared2land's Avatar
    the level of matte-ness...
    That's a good word. I like it.
    Yes, I believe this will be the issue if you choose to provide some spray sealant. Perhaps you will be content with just the new decals and no clear coat?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Barely in control
    Feb 2007
    I do like the decals but the clearcoat helps the edges not tear. I'm going to try upstateSCrider's method.
  1. Replies: 15
    Last Post: 11-16-2017, 01:33 PM
  2. Clear coat over decals into a fresh Powder Coated frame.
    By Pepelepu in forum General Discussion
    Last Post: 01-23-2016, 12:23 PM
  3. Re-painting a frame where the decals are under the clear coat?
    By arcdesigns in forum Vintage, Retro, Classic
    Last Post: 07-13-2013, 01:05 PM
  4. Replies: 6
    Last Post: 07-13-2013, 11:40 AM
  5. Paint or clear coat an SC carbon frame?
    By BTTR in forum Santa Cruz
    Last Post: 06-15-2012, 09:24 AM
Members who have read this thread: 39
