    Jan 2017
    Adapting Park Tool PRS-21 for boost
    I bought the PRS-21 stand a while ago when I only had bikes with QRs. Worked great, got a MTB so I bough the 12x100 and 15x100 adapter. Works great, but now I have a boost 15x110. Is there anyway I can adapt the stand to use this axle. Since you use the thru axle of the bike and the stand is essentially just a hollow tube I imagine something like two 15x5mm or one 15x100mm would work as the thru axle is what really holds it in the stand. Anyone know where I could get something like this?
    Reputation: kbabin's Avatar
    Jan 2017
    I assume so. I found something similar from Sea Sucker. Hopefully it'll do the trick. I'll follow up once I get the spacer.
    Jan 2017
    Well, it works. But it makes the bike a bit more of a pain in the rear end to mount on the stand because it doesn't slide onto the thru axle mount as easily.
  1. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  2. Fuel EX 9.8 + Park Tool PRS-21 Stand?
    By Venge in forum Trek
    Last Post: 07-31-2017, 12:54 PM
  3. adapting a sram oval boost
    By SchwarzBlack in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-24-2017, 12:40 PM
  4. Replies: 35
    Last Post: 02-25-2014, 01:08 PM
  5. Park PRS-5 Pro vs Park PCS-1
    By Demonsmasher in forum Beginner's Corner
    Last Post: 11-17-2006, 08:42 AM
Members who have read this thread: 61
