motolite tire clerance- Mtbr.com
Results 1 to 5 of 5
    Hi
    I am almost there to buy a motolite but since there has been several qestions about tire clerance on the motolite i just wondering if some one can tell me for sure .
    Does the intense cc 2.25 and /or system 4 tire fit ?
    This is very important fore mee because this is the best tire on the trails i ride the most and the tires i trust most .
    Regards
    Simen Kamfjord
    Norway
    Gravity Rides Everything
    Reputation: endurowanker's Avatar
    bump....
    I'd like to know as well.
    Do It Yourself
    Reputation: Homebrew's Avatar
    Quote Originally Posted by endurowanker
    bump....
    The MotoLite has the same chainstay as the Switchblade, Racer-X, and Hammerhead. There have been a couple threads on what fits and what doesn't so do a search. You might check Shiggy's website mtbtires.com for details tire specs. Unfortunately, he doesn't have that tire specifically so you may need to extrapolate.
    Long Live Long Rides
    The swingarm is the same as the pre-2005 switchblades. The largest tire you will be able to get in there will barely be a true 2.3. I tried the Intense system 4 tires on my SB and it was a tight fit. If the tire or rim developed any wobble it would rub on the sides of the swingarm.
    Loser
    Reputation: Jisch's Avatar
    Tire rub
    Quote Originally Posted by Hecubus
    I was running Tioga 2.3 DH tires on my HH100x. There was minimal clearance on the rear, though it seemed to be ok. I got some rub when hitting corners at speed. I checked the chainstays after every ride and the only sign of rub was a shiny stripe. Then I went on a ride where it was muddy, the grit actually scored the chainstay. I imagine I will have to replace the stays at some point. Just a warning - if you ride where its muddy, that rubbing can cause damage.
    John
  1. Replies: 43
    Last Post: 03-09-2004, 08:26 PM
  2. Blur rear tire choice thread from old boards
    By CraigH in forum Santa Cruz
    Last Post: 03-03-2004, 05:16 PM
  3. thirnner tire-more air?
    By ARITAO_BIKER in forum Beginner's Corner
    Last Post: 02-24-2004, 11:46 AM
  4. Advice with Stan no tubes sealent ?
    By Johny Rotten in forum Singlespeed
    Last Post: 02-13-2004, 03:39 PM
  5. Suggestions for WW FAQ section
    By Trevor! in forum Weight Weenies
    Last Post: 01-19-2004, 01:22 PM
