Results 1 to 5 of 5
    Sep 2018
    tandem frame size
    Hi folks,
    We are currently riding a Cannondale MT4000 MTB tandem and many components are getting too old and the frame size is not ideal. That´s why we are thinking of selling it and buying a new one.
    But when looking at what´s on the market as standard frame sizes in Europe (Poison, Drössiger, Lapierre, Duratec) or at Cannondale, all have a back top tube that seems short to me.
    Sure, you don´t want to have your nose too close to the front person and maybe some riders want to see something when they are riding at the back (but come on, it´s more fun not to know when the bike is going to turn. Some people pay for a roller coaster!). But I currently have 72cm top tube length (along tube) for a height of 46cm. That makes both of us sitting at the back vertically as on a city bike. We calculated we would need a length of the top tube of about 88cm to sit at the back as we would on a normal MTB.
    Can you folk explain us why the top tube is always so short? Would it be an error to request a custom frame with a longer top tube at the back?
    Hope you folks can help! Thanks!
    Greetings from France.
    Karo and Manuel
    Reputation: Darth Lefty's Avatar
    Sep 2014
    The length of the boom tube is pretty standard 28.5 or 29 inches, road or mountain, does not vary with frame size. Stoker position is set by the stem and bar, the rear size is purely about seat tube length and stand-over.
    I guess I'd like to hear the case that "modern" trail bike geometry works for a tandem, since it has a lot to do with your fore/aft weight distribution which shouldn't make sense when there's two of you. Something fun to ask in the frame builder forum, maybe.
    If you look at older road racing tandems from the 70's (Motobecane, Paramount, Peugeot etc.) they are a lot shorter than anything today!
    Oct 2011
    Many teams opt to have a longer rear top tube. I don't know why this is not a standard option. Ventana will do this as a custom frame, and other makers will do this also. Our Curtlo was built with a 31.5" stoker top tube back in 2003 and my wife fits in her normal position. At that time it was necessary for him to use a straight guage rear top and boob tube because there were no butted tubes available at that time in the lengths required. That is still probably the case, and may be one reason for the lack of options.
    Sep 2018
    Thanks a lot, it helps to know there are folks out there riding such tandems! I have some more questions for you: Did you notice a pretty low stiffness of the frame (I am worried this might also be one reason for it not to be standard)? Is the distance towards the back of the captain sufficient in your case? Did you opt for the same sitting angle as on a MTB or did you do something in between MTB position and the position you would have on a commercially available frame?
    I think I will talk about this topic with a tandem frame manufacturer and tell you what their opinion on the topic is.
    Sep 2018
    Hi folks,
    I spoke with the manufacturer of the frame. He confirmed he sees no issue in making the frame longer at the back. He also explained the non-availability of longer frames on common commercial tandems by the effort to use the same pieces for all bikes to reduce costs. So they use tubes with a fix wall thickness. As for static you would have to adapt the wall thickness to the length of the tubes and to the weight of the biker and they have to make it work for all weights, they have nearly no other choice than to search for a trade-off between weight (using heavily over-dimensioned tubes for the S size) and tube length (making the L sizes too short).
  1. Custom Tandem Roof Rack: Carries the Tandem with the Wheels On!
    By Nurse Ben in forum Tandem Mountain Bikes
    Last Post: 07-15-2015, 06:46 PM
  2. Replies: 2
    Last Post: 02-28-2013, 08:57 PM
  3. Replies: 0
    Last Post: 08-28-2012, 12:05 PM
  4. Replies: 0
    Last Post: 07-30-2011, 10:23 PM
  5. stolen tandem; need new tandem for century ride
    By gooseguy in forum Tandem Mountain Bikes
    Last Post: 08-23-2005, 01:14 PM
Members who have read this thread: 16
