Results 1 to 5 of 5
    Jun 2018
    Advice needed - Upgrade Older tandem
    I have an older Santana Habanero full suspension tandem. All the riding we do is technical/trail riding. Currently the bike has a triple front chainring setup and lacks gear as low as I would like. I am considering changing from the triple to a 1 or 2 X 10/11. I am looking for advice and comments as to your recommendations. Thanks
    Oct 2017
    What cranks do you have currently? Are you looking to replace those as well?
    How many teeth is the smallest chainring in front?
    How many teeth is the largest cog in back?
    How many gears currently in back?
    Jun 2018
    Hi. Thanks for the reply. The cranks are Shimano
    tandem cranks. Front triple range is 58-32. Rear 9 cog cassette is 32-13. Yes, I am willing to replace all the cranks.
    Could switch to 10 or 11sp in the back and take advantage of the newer/larger range cassettes. Avoid the $ impact of new cranks and BBs, cheaper for a new rear shifter, cassette, and mech if you need it. Depends on how much lower you need your gearing. Shimano's XT 11sp cassettes start at 11-40 and go up from there. That's a big jump from 11-32.
    Sorry, old thread, recently read...
    I found a donor bike with the same bolt count and BCD as my tandem on CL. Paid 20 bucks for a hashed out 1992 something or other, took the front chainrings at 48-36-24 and put them on the tandem.
    Total cost:$20 and my time.
    Still have some extra parts left over in case another opportunity comes up.
    Good Luck with your project.
  1. Custom Tandem Roof Rack: Carries the Tandem with the Wheels On!
    By Nurse Ben in forum Tandem Mountain Bikes
    Last Post: 07-15-2015, 06:46 PM
  2. Help with identifying some mounts/tabs/ect. on an older Lippy tandem frame
    By Andy FitzGibbon in forum Tandem Mountain Bikes
    Last Post: 06-08-2015, 04:50 AM
  3. Replies: 2
    Last Post: 02-28-2013, 08:57 PM
  4. Replies: 0
    Last Post: 08-28-2012, 12:05 PM
  5. Replies: 0
    Last Post: 07-30-2011, 10:23 PM
Members who have read this thread: 19
© Copyright 2018 VerticalScope Inc. All rights reserved.
