Results 1 to 6 of 6
    likes beer
    Ogre through-axle forks - Whatís the best option?
    Any ideas as to the best option to run a through axle, up front? Either converting the original fork or buying a new fork? Iím wondering how the newer Krampus through-axle fork would work, or if there is another steel option that also has cage mounts.
    Reputation: seat_boy's Avatar
    You can't covert the current fork.
    You'll need to know the length of your current Ogre fork--didn't they shorten the fork on the latest model?
    http://www.bikingtoplay.blogspot.com/
    RIGID, not "ridged" or "ridgid"
    PEDAL, not "peddle." Unless you're selling stuff
    Why do you want thru axle? The stock QR forks are just fine.
    Jason
    Disclaimer: www.paramountsports.net
    likes beer
    Quote Originally Posted by seat_boy View Post
    They did, I believe. The current Ogre fork is about 1.5Ē shorter than the current Krampus fork.
    likes beer
    Quote Originally Posted by JAGI410 View Post
    Primarily because Iím considering a through axle rear and having one of each seems a bit of a faff.
    Dec 2012
    Fine isn't necessarily best.
    I've a 2012 Ogre whose front dropouts have always been a little problematic.
    Placement of the front wheel within these slightly large dropouts can easily mean noise from the disk brakes rubbing.
    I've had the frame since new and use a Son28 dynohub with QR.
    When the rubbing initially manifested I gave up and took the bike to two different bike mechanics who both failed to remedy the issue.
    The second one did recommend the experimentation of spacers to bolt the caliber to the front forks.
    Backing off the pads enough to mitigate the noise issue leaves simply too much lever movement to get the brake response I favour.
    I found slightly changing the position of the wheel within the dropouts dispels any noise/feedback.
    Now I've gone ghetto tubeless, I've forgotten the last time I've needed to take out the front wheel.
    I should have a play with some spacers I guess, but I really like the sound of the through axle set up keeping the wheel position exactly the same each time.
  1. Replies: 2
    Last Post: 09-21-2017, 12:56 PM
  2. Replies: 15
    Last Post: 05-24-2015, 07:36 AM
  3. Suspension forks for Ogre/Troll
    By corwin1968 in forum Surly
    Last Post: 11-16-2013, 07:48 AM
  4. Tubeless See Through Windows Option #2
    By alphazz in forum Fat bikes
    Last Post: 11-25-2012, 08:36 PM
  5. best 20mm through axle wheel or sets for dj
    By *B* in forum Urban/DJ/Park
    Last Post: 10-08-2011, 02:02 AM
