Moonlander MWOD fit on Pugsley?
Wondering if I can use a stock 2X ML MWOD Crankset on a Pugs.
And if the cranks fit can I run 82mm rims with BFL's?
I believe the spindle length is different and specific to ML, so no go.
Yes, it will fit. I have that crankset on my Pug Ops. It came on the complete build. Both the Moonlander and Pugs have a 100mm BB shell.
As to the tire question, I dont think there's any way you can clear anything larger than a 4" tire in the rear.
I don't think this is correct. I believe the Moonlander has a longer spindle as stated above to account for wider chainstays. Which are wider to fit 5" tires.
My thinking was that maybe you could fit the ML version MWOD on a Pugs and just have a wider Q factor. Not sure if the chainline would be off though.
By SpicyMac in forum Fat bikes
Last Post: 09-21-2015, 02:17 PM
By BigAngryGuy in forum Clydesdales/Tall Riders
Last Post: 02-10-2014, 09:49 PM
By Larry Endomorph in forum Fat bikes
Last Post: 06-10-2013, 09:19 AM
By XJaredX in forum Fat bikes
Last Post: 02-10-2013, 06:45 PM
By thickfog in forum Fat bikes
Last Post: 12-06-2011, 05:08 AM
- You may not post replies
- You may not edit your posts
Forum Rules
