Large Marge and rim tapes.- Mtbr.com
Results 1 to 10 of 10
    Just Ride!
    Reputation: Pigtire's Avatar
    Well finally orderd my parts to build a Pugsley and one of many questions is what type of rim tapes do you use for the Large Marge rims?
    Devo
    Reputation: SelfPropelledDevo's Avatar
    i just used some funky light red nylon fabric tape. its ghetto, it works, and its been over a year now. no problems. I keep wondering when someone is gonna try Stans notubes. It seems that some kind of bi-directional packing tape would work.
    www.AsanaCycles.com
    "Bicycle Lifestyle, realized." D.G.
    Dec 2005
    Surly also sells rim tape to match the width of the LargeMarge.
    I run the Marge XC rims and have had issues with the rim tape folding while changing tubes and an exposed rim cut-out has caused a couple of flats. I've used both generations of Surly rim tape without much improvement. Other tapes will leave adhesive on the rim which can be a pain to clean. I was wondering if anyone has found a plastic strip or similar product that won't fold and doesn't really need to be glued in place?
    Hockey stick tape from Gart's, Herman's, Sports Authority, whatever store is in your area. It come in different widths. I supposed you could spend the $$ on some made for high tech rim tape.
    Just Ride!
    Awesome! Looks like time to head out to Home Depot and see if they have any cloth or packing tape that I could score. Parts are shipped so now I play the waiting game
    One wheeled
    Reputation: Dirtsurfer's Avatar
    Quote Originally Posted by SelfPropelledDevo
    The problem with the Large Marge is the pinned joint. Because Stan doesn't make a rubber strip wide enough, you will have to use a little more latex until it fills the gap. The widest strapping tape does help, but I would prefer it welded. I've been running a Large Marge/Gazzalodi 3.0 for three years without a problem.
    Reputation: bighit's Avatar
    duct tape on mine.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    Jun 2005
    Quote Originally Posted by bighit
    duct tape on mine.
    me too
    Devo
    there is this crazy strong bi-directional strapping tape out there. i use to use it for "hinge tape" on R/C gliders. i think its made by Scotch, 3M...
    www.AsanaCycles.com
