I have one of the latest generation Krampus frames and I am looking to lighten her up a bit. I'd like to get the Salsa Firestarter 110 fork so I can cut weight, but not give up the Anything cage mounts. The Axle to crown is exactly the same on both forks, but the stock fork is 47mm offset while the Salsa is 51mm. I've ran the numbers through one of the trail calculators for a bunch of different plus bikes and it looks like even with the 51mm fork, the trail would fall somewhere in the middle of all of them, so in theory it shouldn't ride all wacky.
Has anyone actually tried running a fork with a longer offset on one of the new Krampus frames? How does it ride?
