Results 1 to 8 of 8
    Jul 2015
    New question here. Help: Fitting Chris King ISO 135 Fun Bolts to KM Ops
    I've been running my KM as SS for a while, but decided it might be fun to throw some gears on it. I picked up a Chris King wheelset (ISO 135mm + Fun Bolts), but I can't figure out how to fit it to my KM now.
    I blindly thought 135mm SS to 135mm 10-speed would just work, but it doesn't appear I have the right MDS bits (I have figures 1, 2, 4 and 5).
    My derailleur is a SRAM XX 10-speed (not direct mount). I attempted to setup my wheel with the figure 4 bits, but that appears to take the frame spacing to 142mm (and requires a direct mount derailleur).
    Do the figure 3 bits require a 142mm hub? If so, could I simply use the figure 5 bits instead of the CK Fun Bolts?
    tl;dr: How do I fit a Chris King 135 x Fun Bolt 10-speed hub to a Surly Karate Monkey Ops?
    Apr 2016
    Fun bolts?
    Sent from my SM-N920V using Tapatalk
    Apr 2016
    I just 10 minutes ago fitted a 11 speed Shimano XT M8000 cassette to a King 135 hub for my Yo Eddy, fit fine. I'm not very knowledgeable on single speed rigs though but 135 is 135.
    Jul 2015
    Quote Originally Posted by dubya3 View Post
    Fun bolts?
    https://chrisking.com/products/510
    It's a Chris King axle type where two 12mm bolts thread into each side of the hub.
    This is pretty different from what I'm trying to do since my hub isn't QR and my frame has Surly's modular dropout system.
    Apr 2016
    I'll bow out, this is alien territory to me...lol. Good luck!
    Not really fixed.
    Feb 2016
    You should use #1, just thread the bolts in most of the way before inserting into the dropout. The funbolt uses a 12mm thread, but it's necked down to 10mm at the head to fit in a standard dropout.
    Did I catch a niner+?
    Quote Originally Posted by pdxfixed View Post
    Hope has a very similar setup with their SS hubs and this is what I did. Just thread them in part way than slide in to the drop out. Or slight the wheel in than do one side at a time.
    Jul 2015
    Winner, winner, chicken dinner! This worked perfectly. Thank you!
  1. King SPAM: BNIB Chris King Rear Hub w/ Fun Bolts Cheap
    By jonshonda in forum Wheels and Tires
    Last Post: 09-12-2015, 08:56 AM
  2. Chris king 135mm to 142mm conversion
    By gio in forum Wheels and Tires
    Last Post: 01-07-2013, 06:49 AM
  3. Converting Chris King 135mm Rr to 142mm
    By JQHansolo in forum Wheels and Tires
    Last Post: 11-20-2012, 01:20 PM
  4. chris king 135mm x 12mm sold out everywhere?
    By lifeis11 in forum Wheels and Tires
    Last Post: 06-03-2012, 09:42 PM
  5. Chris King 135mm x 10mm Axle?
    By rangerbait in forum California - Norcal
    Last Post: 03-12-2011, 11:51 PM
