cross check size- Mtbr.com
Results 1 to 5 of 5
    cross check size
    I recently bought a cross check complete size 54cm. I am wondering now if I should have purchased a 56. With the stock stem(105mm) I can see the front hub over the bars. I am now running a 120mm stem and my view of the hub is obscructed by the bars. Standover clearance is about an inch and a half. The only problem I have now is that my neck feels a little uncomfortable when riding on the hoods, looking forward. I am 5ft 9in with a 32 inseam.
    thanks for any help
    Reputation: Forrestf's Avatar
    Try a stem with more rise to get the bars higher.
    Daddy of 3 now!
    Reputation: daddy2's Avatar
    I've never rode the CrossCheck nor any road type bike prior to buying and I'm still wondering about the fit. I'm 5'10 - 32" , choose the 54 w/Thomson Set back post and 100mmx40rise w/Moustache bars. Seems to be spot on even al little stretched out and yes I can see the front hub over the bars if I'm all the way in the drops.
    Btw, I love the ride!
    I'm thinking about trying the Midge bars w/100x5 stem.
    The steel is comfy
    Duckin' Fonuts.
    Dec 2005
    You are the same height and inseam as me. I ride a 54 with a 110mm stem and 15 deg. rise.
    thanks for the feedback.. after a week of breaking in, the fit of the 54 is starting to feel good.
