Cross Check - Singlespeed Wheel Slip- Mtbr.com
Results 1 to 11 of 11
    I have a geared cross check. I am thinking of changing this to singlespeed by using spacers and a single cog onto a Shimano freehub.
    How can I stop the front wheel from slipping forward in the dropouts under load?
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    Quote Originally Posted by Ridders
    front wheel???
    D'oh
    Spot the obvious mistake! Rear wheel....
    Cob up a chain tug. You may end up needing to grind some stuff off the tug, and it won't look sweet. But it'll be functional. Just set up the chain tug same as you would if the bike had rear facing dropouts. It'll work. Be creative.
    My tapeworm tells me what to do.
    lord of my world
    Reputation: surlywhore's Avatar
    Dec 2005
    If you are running a Shimano hub switch out the QR axle for a bolt on. Slows down tire changes but, the axle won't slip and you don't have to run ugly chain tugs.
    Obi
    Obi is offline
    -_-
    Idea!
    Quote Originally Posted by surlywhore
    Ditto that. Tugs won't work for your type of forward facing dropouts. An axle shouldn't run more than around $20.00, and might even be available in a hollow design to save some weight over a solid one. Let us know what you do, in fact, might make a good conversion article for in here.(Hint-Hint)
    Obi..
    I won't beat this solution into the ground.
    http://gallery.mtbr.com/showphoto.php?photo=23612&password=&sort=1&cat=500 &page=1
    I had the same problem. I just used a Surly Tugnut. I just tightened it up against the back of the drop outs.
    Dec 2005
    I have an old trek 760 road bike set up as a singlespeed. It too has forward facing horizontal dropouts (campagnolo). In fact this is the second bike I've had like this. I run it with a QR on an old Dura-Ace hub with spacers. No slippage problems at all. You just really have to clamp it pretty tight. This bike is mostly my commuter, but I've also done 60+ mile rides on it with no problems... Just don't use a fancy QR skewer. The old heavy steel kind is what you need.
    Edit: I should also mention I'm a really big dude (6'5", 250) and I'm running a 40x15 gear...
    Reputation: Polk's Avatar
    I "second the motion" to change a Shimano (or any cone bearing hub) to a bolt-on axle. I have done that with a couple Shimano hubs and it works well.
    Dec 2005
    What keeps your geared wheel from slipping forward in the dropouts?
    The forces on a geared wheel can be even worse than a SS wheel. So if it works for your geared wheel it will work for your SS wheel. I run an old touring bike with similar dropouts as a fixie without any problems. I perfer a bolt on wheel but you really don't have to change anything just crank down the tension on your QR.
    Craig
