    Aug 2010
    83mm Wednesday BB?
    Anybody reduce the BB on their Wednesday to 83mm?
    Cost? Complexity? Crank options?
    May 2010
    Is there enough BB shell exposed to shave it down that much?
    I thought of doing that with my Pugsley. But ended up going with a square taper set up. WI road cranks. Got the q factor down to 183mm.
    Aug 2010
    83mm Wednesday BB?
    Quote Originally Posted by 2:01 View Post
    Not sure, but it looks close on the DS.
    Iíve read about this Mod on the Pugs and was wondering if itís doable on a Wed.
    Then I thought maybe you could take more off on the NDS to make up the difference.
    May 2010
    You probably could. And then use spacers to even out the cranks as much as possible.
    But in reality, it was easier to get ST cranks and leave the BB shell alone.
  1. Non-boat anchor cranks for 83mm bb shell?
    By uphiller in forum Weight Weenies
    Last Post: 04-18-2011, 02:25 PM
  2. Not heavy cranks for 83mm bb?
    By uphiller in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-16-2011, 06:02 PM
  3. new frame:rear hub 150mm or 135mm?, bb 73mm or 83mm?
    By paul29er in forum Clydesdales/Tall Riders
    Last Post: 04-16-2011, 10:21 AM
  4. Front derailer for 83mm BB and 42T big ring
    By paul29er in forum 29er Bikes
    Last Post: 03-14-2011, 09:47 PM
  5. 73mm BB with 83mm Cranks. on a 135 rear
    By the_owl in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2011, 06:41 PM
Members who have read this thread: 8
